Aug. 2011 pri II - idles up a little before shutdown during running
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rrg, Nov 19, 2011.
  1. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Since the weather has dropped a little I was wondering if it's normal that the car sitting on in the drive way, on, would idle up a little just before shut down. I mean shutdown to use the battery not shut down turn the car off.
    It idles fine for the warm up stage then just before it shuts down to be available for ev mode it spins up a little.
    I will need to monitor the RPM to see how high it idles up.
    It never did that during the warm months in Aug or Sept.
    thx.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, that is normal. I would say mine does that about half of the time.
  3. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Mine does that also out here in tropical Hawaii. IDK if it does it all the time or not thought but when I do listen to the engine I hear it. When I do pay attention and listen and hear the RPM increase I can tell when the ICE is going to shutdown.
  4. srevelation
    srevelation Junior Member
    25
    Pennsylvania, USA
    Yup, I hear this regularly. As dustoff003 says, I've learned that sound means it is about to shut down and ICE is warmed up.
  5. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    I think it is pretty normal. The ICE just prepares itself for next easy start.
