Auris 2015 hybrid
Discussion in 'Toyota Hybrids and EVs' started by luisneto, Jul 20, 2021.
  1. luisneto
    luisneto Junior Member
    aveiro
    Toyota Auris Europe model with 150K.
    I've been working in this model in the recovery of the hybrid battery, I've already separated the most used, medium and best modules. I have already replaced the ones that were more spent, equalize process, so on, but it happens that when there is a discharge below 30% the battery error appears. It never happened to me with other models. It seems that the battery management system for some reason does not charge when it should and then causes the error.
    It seems that something is failing me, forget.
    Does this model have to be reprogrammed in battery management in order to avoid errors? I know that there were Toyota models that had to be adjusted in this detail and I suspect that this situation may be happening in this model (the schedules were not updated)
    What can the more experienced ones tell me about this subject?
    Many thankĀ“s
