Auris hybrid
Discussion in 'Newbie Forum' started by Stuart Park, Nov 30, 2018.
  1. Stuart Park
    Stuart Park New Member
    Uk
    Business Edition
    Hi I'm wanting to buy a 2017 auris hybrid with 6 thousand miles on it.
    I've read the auris suffer from 12v battery problems. Is this still the case?
    Also does the 1.8 engine suffer from any major problems. I'm wanting to keep the car for around 7 /8 years
    Data Daedalus likes this.
  2. PriusCamper
    PriusCamper Senior Member
    11,190
    4,559
    Pacific Northwest, USA
    Mo
    They're more reliable than most cars... Gen2 Prius (2004-2009) are mostly still going strong and have lasted way longer than people expected. Take a look on the roads around you, you'll see them often. Gen3 Prius have a few more failure issues than Gen2 and too early to know about Gen4 Prius like the one you want.
    Fostel and Data Daedalus like this.
    49,692
    welcome!
    there have been a spate of bad 12 volts, mostly under warranty. definitely worth testing before you buy.
    no major problems yet, except one blown head gasket the was reported here. but the night is still young. all the best!(y)
  4. cdurnal
    cdurnal Junior Member
    Daisendorf, Germany
    We bought a new 2017 Auris hybrid here in Germany and love it. We've had no problems.
    Data Daedalus and bisco like this.
  5. difficult
    difficult New Member
    Greater Manchester
    Excel
    I have been using Toyota Auris dec 2014 model for good few months.
    Its fully loaded car, with leather seats and its very reliable and very smooth to drive, compare to my previous cars life Nissan Note and Honda civic.
    I have had my car mot and service done under £120.00 and there is no fault at all.
    As far I know, these cars has less faults then normal petrol /diesel cars.
    You need to make sure that you buy genuine parts from Toyota to service your car.
    Fostel, Data Daedalus and bisco like this.
  6. bisco
    49,692
    you're not being difficult (n)
  7. difficult
    Greater Manchester
    Excel
    But my life is....
  8. qettyz
    qettyz Active Member
    181
    206
    Finland
    Auris TS 2014 owner here. Ive had car now 1.5 years and ~30k km.
    Everyday i love driving that.
    I believe you have found those 12V battery problems from older Auris news. First mk2 (2013->) models had software bug before they fixed it: you could trigger ECU being live ”forever” by touching hazard switch very gently. It then drained 12V battery.
  9. bisco
    49,692
    interesting. we've had some gen 4 12v issues over here, but i don't recall reading any solutions.
  10. qettyz
    181
    206
    Finland
    Toyota Auris owners - 12 volt flat batteries - Toyota
    It was 2012-2014 Auris problem, remembered wrong.
    What causes the issue?
    The issue is caused when the hazard switch is partially depressed for a very short period of time, incorrectly activating the car’s CAN-bus electrical communications system. This draws a constant flow of current that can discharge the 12 volt battery if the car is left unused for several days.
    How can I prevent this from occurring?
    Toyota has published a Technical Service Bulletin to its dealer network advising them of a permanent solution to this issue. The bulletin contains information and software files that will enable technicians to modify the software of the car’s combination meter. This update will prevent the incorrect activation of the CAN-bus system and prevent any potential flat battery concerns arising from this area of the vehicle.
  11. bisco
    49,692
    ah, thanks!
  12. qettyz
    181
    206
    Finland
    Strange if still Prius gen4 have had this issue, i would think that Toyota would have learned from this.
    Edit: i read wrong, you did not say that its same ecu thing ;)
  13. bisco
    49,692
    you're a naughty boy :p
