Austin TX - Coolant Control Valve Change
Discussion in 'Gen 2 Prius Main Forum' started by caliwaves, Jan 18, 2022.
  1. caliwaves
    caliwaves Member
    65
    32
    TX
    Hey all! Been a while. Trying to help a friend out. He was quoted $160 labor to replace his coolant control valve, which he'll be bringing a brand new OEM part. They also quoted $40 for 2 gallons of coolant. Wondering if that sounds right or if there are other recommendations?
    Thank you!
    49,492
    was that a dealer? anyone could do it
  3. caliwaves
    caliwaves Member
    65
    32
    TX
    Hey @bisco, that was an independent shop
  4. rogerthat
    rogerthat Active Member
    363
    118
    Georgia
    Make sure whoever does the job only uses Toyota SLLC. However, you might want to read up on changing the engine coolant in the gen 2 Prius - it's extremely difficult to bleed all the air. First time I'm really thinking about it, but perhaps you can change that coolant control valve without draining by using hose pinch clamps.
    #4 rogerthat, Jan 18, 2022
    caliwaves likes this.
