autel ap200
Discussion in 'Gen 2 Prius Technical Discussion' started by Tombukt2, May 17, 2024.
  1. Mendel Leisk
    42,366
    Copied. :)
    Might need it someday, and that day may never come, hopefully not.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,070
    956
    Southern California
    Link?
  3. Mendel Leisk
    42,366
    I floundered for a bit, think the expression is:
    Initialization and calibration of the linear solenoid valve
    Found this:
  4. pasadena_commut
    3,070
    956
    Southern California
    Note to self - let a mechanic do this. What a complicated and mysterious set of operations.
    I looked in the 2004 Gen 2 brake manual and didn't find any notes about doing this without Techstream. Searched for "not using" and it didn't find a section that corresponded to the "When not using Techstream" section in that attachment.
    On the other hand, I did stumble upon this classic:
    which is pretty close to "smack the case with a wrench and look for changes"
  5. ChapmanF
    19,046
    Intermittent problems caused by wire harnesses and connectors are, I think, more common than those caused by cases, which may go some way to explaining why they included the "jiggle harness and connectors" test but not the "smack case with wrench" test.
    (In the early, introductory sections of repair manuals, they also mention some other classics, like the "heat with a hair dryer" test. I'm not sure those sections always get included in the PDF repair manual versions that float around.)
  6. pasadena_commut
    3,070
    956
    Southern California
    "Smack case with wrench" applies a global shock to wiggle all connectors at once, and all other types of loose connections, like a bad solder joint. It is a test applied before one opens the case and wiggles each connector one at a time and hunts in earnest. No change on test doesn't inform much (negative result doesn't rule out connection issues) but observing a change with the smack is informative. Not good to hit most places on a car with a wrench, but driving it on a very rough bumpy road may work.
