Auto cruise control. And monitor brightness.
Discussion in 'Prime Main Forum (2017-2022)' started by Loriann, Sep 23, 2020.
  1. Loriann
    Loriann Junior Member
    Rochester ny
    2020 Prius Prime
    Hello again. I was told I can use the auto cruise control even in the City, so I have. Is it better has per mile or am I better to Drive this in the 55 mph area?
    Also, I can’t always read the monitor, can I adjust the brightness of the screen?
  2. Loriann
    Rochester ny
    2020 Prius Prime
    Also, on the dash is MPG. Earlier it read 999.9. On lunch it read 76.9. What is the difference? Why such a drastic change?
    thanks everyone
  3. fuzzy1
    10,049
    The earlier 999.9 sounds like all-electric driving. The later 76.9 sounds like the traction battery charge ran down and it switched to gasoline. How many miles later was this? Did you do any recharging in between?
  4. Loriann
    Rochester ny
    2020 Prius Prime
  5. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    For simple questions you have, you should consult your owner's manual before asking the community for help. I suggest downloading pdf version of the manual on you computer or phone and use the "search" function to find the appropriate sections quickly. Here is the link pages for your manuals: 2020 Toyota Prius Prime Owners Manual and Warranty - Toyota Owners
    You can use DRCC at 55mph area, but doing so may or may not improve the efficiency. To engage, car need to be at or above ~30mph. In my experience, if I have a lot of stop and go, DRCC does not help the fuel efficiency. Even at smooth moving light traffic without stop at 55mph, I have found I can control the pedal better than DRCC to get better fuel efficiency. I use DRCC only on very long highway drive just to rest my foot.
    For changing the instrumental cluster light, you can adjust the brightness by the switch on the left side of the steering wheel.
    If you are talking about the 7" LCD screen in your LE model, then the MENU button on the multimedia, then Display will give you the adjustment choice.
    #5 Salamander_King, Sep 24, 2020
