Auto dim headlights
Discussion in 'Gen 4 Prius Main Forum' started by CharlesLewis, Oct 4, 2017.
  1. CharlesLewis
    CharlesLewis Junior Member
    24
    US
    I have noticed that I keep having to turn on the auto headlight feature. Once on it works fine, but on another night trip, it's off and I have to reset it.
    I don't drive much at night, but it seems to happen each time I start a new trip. I thought at first I might have hit the switch opening the gas cap, but that's not the case.
    Isn't this supposed to stay on unless I turn it off or is this the way the feature is designed?
  2. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    it's called auto-dim ... it means that it need to be On to work.
    You need the auto-dim switch to be On AND ALSO the stalk on the steering wheel set to High Beam position... if the auto-dim is On and the stalk is set on low-beam .. nothing will happen.
    RCO likes this.
  3. CharlesLewis
    24
    US
    I understand that. The stalk is on high beam. The problem is that when I press the button for auto-dim, it seems to switch off when I cut off the engine and I had to switch it back on the next time I drive after dark.
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    The button for auto-dim is an always on or always off. Once you turn it on, it will only turn off if you press it again to turn it off.
    FuelMiser likes this.
  5. CharlesLewis
    24
    US
    That's what I assumed, but it IS turning off, so I must have a problem.
    Thanks
  6. Flaming
    138
    123
    QC , Canada
    Technology
    Oh .. that's odd ...mine stays on all the time , but i noticed that it super sensitive and does not need a big push on the button to turn it Off / On
  7. CharlesLewis
    24
    US
    I thought about that and wondered at first if I had but it when I popped the gas cap, but it has happened even when I didn't get gas (love the gas mileage!).
    RCO likes this.
  8. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    When the button is on the 'on' position can you feel that it is slightly lower than the other buttons around it? and when you go to use it and its not working does it still feel recessed or feel flush with the other buttons and are you having to click off and click on again to get it to work?
    RCO likes this.
  9. CharlesLewis
    24
    US
    I'll have to check this weekend. Thanks for the suggestion.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Could you be catching it with your knee when you get in ?
    RCO and Prodigyplace like this.
  11. CharlesLewis
    24
    US
    I hadn't thought about that. I'll experiment to see.
  12. CharlesLewis
    24
    US
    That must have been it. They worked fine last night. I'll just be careful getting in.
    Thanks for solving the mystery.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I've done it myself, I don't usually have Auto Hi-beams on but I have occasionally accidentally caught the button with my knee and turned them on.
    RCO likes this.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Another case of kneed to know. :whistle:
    jtv and kithmo like this.
