Auto-dimming mirror in IV - cr@p
Discussion in 'Gen 3 Prius Technical Discussion' started by mmcdonal, Apr 4, 2011.
  1. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I bought the prisms from Anchor Optics here. I don't remember which ones I got, exactly -- I believe they were the 10x14x10 ones.
    As for mounting, I used something called "dum dum" or "ribbon" sealant. It's like super sticky sticky-tac which doesn't change its elasticity, pliability or durosity due to temperature changes. I believe it's available at Napa or, if you have a good relationship with your Service Advisor, I'm sure s/he would be able to get you a piece of it from one of the mechanics -- they all have it. I used four balls, each the size of a large b.b. and just mashed everything together. It's held for over a year now with absolutely no signs of giving way whatsoever.
  2. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    It is a horrible design. You can see the light not hitting the sensor.
  3. BrettS
    BrettS Active Member
    290
    137
    Orlando
    No, it just dims the interior mirror.
  4. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Mine always worked fine. I'd try adjusting it. :)
  5. Tideland Prius
    16,684
    No. Interior rear view only
    My experience was with a 2002 Camry. It worked really well even with the rear sunshade in place.
    And the Camry Hybrid does not have auto-dimming side mirrors. So far, Toyota has kept that feature, for the most part, for their Lexus models. However, I believe the Sienna Limited does have a driver's side auto-dimming feature as well as the Avalon Limited.
  6. nicolengr
    nicolengr Junior Member
    Kansas
    The electrical tape worked brilliantly for me, cover most of the sensor on the back of the mirror and it works like it should.
  7. cashewfeni
    cashewfeni New Member
    VA
    I notice that most of you all have given up on this topic (no posts in 2012 so far). You guys probably got used to this problem and moved on. I just bought a certified 2010 Prius IV, after selling my first gen prius, and am horrified with how poorly the auto dim mirror works. I have called Toyota 3 different times and each time, they say they have never heard of this before. When I go to a dealer, they say they have received several complaints. Then, they shine a flashlight on the rearview and declare that it works great. When I tell them that the 30 odd cars that are following me on the highway don't quite come into the cabin and shine dainty flashlights in my rearview, they say "well-that mirror is a design characteristic of the car. It is not a flaw". One Service manager said that he sees this when husbands let their wives drive as the wives tend to sit closer to the steering and angle the mirror to sharply.
    Can you guys just call Toyota and let them know of this problem? How about a class action lawsuit? The only manner in which I can drive my car at night now is to lower the rearview so I can't see anything in it.
  8. cashewfeni
    VA
  9. Tideland Prius
    16,684
    You want a class action lawsuit on a product that works??
    The mirror is the same one used in a lot of different vehicles (not just Toyota), so yes it works. It's the design of the Prius that renders it less effective than a regular car. The reason is that the rear spoiler is just at that height between the headlights of the car behind and the mirror's light sensor. The rear spoiler blocks the light so only scattered light hits the mirror. (and this is one when the service folks shone a light on the sensor, it dims)
  10. Tideland Prius
    16,684
  11. Tom_06
    Tom_06 Active Member
    609
    143
    Newark, Delaware, USA
    Back when I got my 2006, this was an item of discussion. One recommendation was to rotate the mirror upside down. This puts the sensor in a better place for picking up light from behind. It only can turn one way due to wires. A search of the GenII forums will probably turn this up or you can just try one way or the other gently.
    This wouldn't work for me because I use the HomeLink buttons for my garage door and home lights. I didn't want the buttons at the top and upside down. John1701a came up with a neat solution. Go to http://john1701a.com/ and look at the left side of the screen. Click on "Prius Info" and search down for "Electro Mirror Mod". He just put "sunglasses" on the forward facing sensor with a bit of transparent blue plastic. That made it way more responsive.
  12. Tideland Prius
    16,684
    Yup. The mirror in our 2005 is upside down and we use the Homelink buttons. (It's natural by now).
    You can't do that on the 3rd Gen (that was one of the first things I tried). The mirror is mounted closer to the headliner.
  13. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    That seems like a pretty neat solution --- much better than the prisms.
    The mirror in my 2004 has the same problem. I know the technology works because I have a 2010 Honda Odyssey and that mirror works much better.
    I am going to try the tape fix, perhaps using gray or smoke tape rather than blue; maybe a little less of it to make this less noticeable from the outside.
    I certainly hope my new 2012 doesn't suffer from the same issue. If so, I'll mod that as well, assuming the mod on the 2004 works.
  14. AZGeek
    627
    144
    63
    Arizona
    I tried this and got mixed results. I used four sandwiched of pieces of exposed 35mm negative film and taped over the front facing sensor. The mirror seemed to darken much quicker, but was still inconsistent on when it would darken. I think this is really more of a function of the rear spoiler blocking the light to the mirror.
    But the wierd thing was driving around today and the mirror stayed dimmed the entire time. I removed two of the layers and the mirror returned to normal for daylight operation. I'll try driving around at night in this configuration to see if this helps things out.
    I'd be curious to see the heights of those of you who say the mirror is working fine, because I think you may be able to adjust the angle of the mirror that makes the rear spoiler less of a problem than for those of us "sub-6 footers".
