Auto door locking
Discussion in 'Gen 2 Prius Technical Discussion' started by mtk525, Aug 29, 2007.
  1. jpmorgan49
    jpmorgan49 Junior Member
    17
    Joliet, IL
    <div class='quotetop'>QUOTE(aaf709 @ Sep 8 2007, 07:33 PM) [snapback]509306[/snapback]</div>
    I just read the manual on my 2008 Prius. On page 448 "Customizable features" It says "Your vehicle includes a variety of electronic features that can be personalized to your preferences. Programming these preferences requires specialized equipment and may be performed by an authorized Toyota dealership." Under item "door lock" The function "speed-detecting automatic door lock function' the Default setting is "off" the Customized setting is "On".. Could it be that easy? I bring my Prius to the dealer and say change this customized setting? It looks that way. I've included a pdf file of the manual.
    jp
  2. jonjonbear
    jonjonbear New Member
    105
    Bastrop, TX
    <div class='quotetop'>QUOTE(jpmorgan49 @ Oct 2 2007, 09:23 AM) [snapback]520267[/snapback]</div>
    I just pulled my manual out to look at that. It also says the default setting should lock the doors when taken out of park and putting in park should unlock. Both show "on" as default yet my car doesn't do this..I wonder if these are turned off in port? I would love it to do that..I had a Lincoln that did exactly this..I think I would have the speed lock turned on and putting it in park unlocks turned on if possible..I wonder if anyone has done this?
    John
  3. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    jpmorgan, is that your phone number on that faxed spread from the manual? Just an FYI ;)
  4. jpmorgan49
    17
    Joliet, IL
    <div class='quotetop'>QUOTE(Ichabod @ Oct 2 2007, 11:18 AM) [snapback]520380[/snapback]</div>
    Oops, no I faxed it from work...... :blink:
  5. blamy
    blamy Member
    380
    Central Florida
    <div class='quotetop'>QUOTE(mtk525 @ Aug 29 2007, 05:48 PM) [snapback]503979[/snapback]</div>
    I used the Coastal Lock in my 2007 and it works just fine and better yet was very easy to install! With foot on the brake you push the button and the doors lock. Simple as that. Took about twenty minutes to install and put everythng back where it belongs. The directions were very easy to read and follow. Enjoy!
  6. jpmorgan49
    17
    Joliet, IL
    <div class='quotetop'>QUOTE(BuddyL @ Oct 3 2007, 08:08 AM) [snapback]520558[/snapback]</div>
    This Auto Lock thing has really been bugging me. The manual says Yes and everybody else says No. I finally called Toyota and told them my dilema. I asked please tell me "Yes" or "No" can I program my Prius to have the doors auto-lock. He put me on hold and when he came back he said I have a definate answer for you . He said the Prius CAN be programmed to have the doors automatically lock but unfortunately the dealers do not know how to program that feature at this time. He did say that the dealers should know within a week or so. So it looks like I can program my prius to auto lock the doors..... as soon as the dealers figure out how to do it.. :blink:
  7. jonjonbear
    105
    Bastrop, TX
    <div class='quotetop'>QUOTE(jpmorgan49 @ Oct 15 2007, 01:25 PM) [snapback]525923[/snapback]</div>
    JPmorgan,
    That is awesome! Thanks for sticking with this. That would be great to be able to do it as the manual states..
    Thanks again,
    John
  8. PhilWray
    PhilWray Member
    82
    28
    Malaysia
    Hi All,
    I have just picked up a 2004 UK model T-Spirit. Has anyone had any experience with using this on UK versions. I will also email Coastaletech support but from other posts I have seen it may be a while befor i get an answer!
    Regards,
    Phil
  9. Qlara
    Qlara New Member
    488
    The 2008 Owner's Manual also said Driver and Passenger can set the Temperature seperately (like Dual Climate Control)? Is that true?!
    I kind of lose fate on what the Manual said about the features we 'may' have....which was referred to the non-US Prius. Not to mention there're typos in some paragraphs too......
    Keep us posted if your dealer can actually program the Auto-Lock.
  10. chadster
    chadster New Member
    29
    West Hills, CA
    I am sympathetic to the lack of auto locking doors on the prius. My wife went from a 4runner (which has auto locking doors) to the prius and until now forgot to lock the doors quite often.
    I am mass producing an automatic door locking feature (for the 2004-2009 prius) that locks the doors when you initially power the prius up such as when you press the brake pedal and push the power button. It will be available via the prius chat store in the next couple of weeks. It is a plug-and-play device in that it plugs into existing channels that requires only a screwdriver for installation. It takes about 20 minutes or less to install. There are full-color instructions and I will be available for assistance if the need arises.
    The value of the safety aspect of this feature makes it a worthwhile purchase. Stay tuned.
  11. rfruth
    rfruth Member
    394
    Houston, Tx
    I'm no fan of the auto-locking feature, but glad its a hardware / firmware option for those that want it.
  12. aaf709
    3,862
    2022 Prius Prime
    The Coastal Auto-Lock on my 2005 locks when I reach 16 mph. The funny thing is that I have cut the speed sensor wire for the BT and installed a push-on/push-off button. If the button is in the Off position, the doors lock when I press Power.
  13. chadster
    chadster New Member
    29
    West Hills, CA
  14. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    just want to share.. I have an 08 model and when I press power with my foot on the brakes the car automatically locks all doors and when I turn it off it unlocks all doors.
  15. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    Aftermarket mod? That did not come stock - for sure! Have video?
  16. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    when I got the car it already does the auto lock...
    sorry got no video.... if you'll read the thread below... the same thing happens to my car...
    http://priuschat.com/forums/prius-technical-discussion/38789-auto-door-locks.html
    if you'll read the post made it locks when you press start without putting on your seatbelt... but when you put on your seatbelt before pressing start it won't lock....
  17. wolfganghowell
    wolfganghowell New Member
    Hello
    I have a 2008 Prius and purchased an auto-door-lock module from CoastalEtech (www.coastaletech.com). I installed the product but the doors do not lock. I checked all wiring and made sure it was installed exactly as documented. I also purchased the EV module from them and it works great!
    I have sent several emails to their support email address and I am not getting any response from them.
    I was wondering if anyone else is having trouble with their support?
    Thanks
  18. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Wolfgang, Coastal tech's lack of custoemr service is legendary. many posts here of horror stories galore. Just do a search on coastal tech and see.
    I would never do business with people like that!
  19. wolfganghowell
    Thanks Sheepdog,
    I learned my lession. I should have researched their company a little bit more. They WILL NOT answer any of my emails.
    I am now forced to see if I can figure this circuit out and fix it myself.
  20. berinker
    berinker New Member
    43
    Santa Barbara, CA
    Where do you get the seat covers and the dash cover that you mentioned
    that you have for your Prius?
    Thanks,
    Bud
