Auto lock doors?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Frank Perkins, Nov 19, 2012.
  1. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I have my advanced PIP set to lock the doors at 5mph when I drive. This is a setting, lock in Drive, or lock at 5mph.
    You have to manually lock the doors when you exit the vehicle.
    Would be nice if the car would lock itself when it no longer senses the key fob.
    But then what would happen if you are driving and the battery in the key fob dies?
  2. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    SKS will not let you lock the door if the key is inside. Try leaving the key inside and press the door handle button, it will give you a weird beep sound and not lock.
    SJ PiP likes this.
  3. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    The aftermarket alarm in our Expedition has this feature enabled- my wife has been locked out several times because of it. One time was at a gas station where she went inside to get something only to find a locked car on her return. It's a horrible "feature".
  4. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    A pretty easy technical solve by simply not automatically locking the doors if the car is in park and the key is within range.
  5. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    It is solved see my post above.
  6. hill
    9,038
    sure you can ... just set the SKS in your car - roll the driver's window all the way down - with ignition on, get out - shut driver's door - reach through the driver's window and turn ignition off - hit driver's window "Up" button ... viola ... you're locked out
    :p
    SGH-I717R ? 2
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    You shut down the car down right? In my case, I think I left the car on and went away. The car was locked when I returned.
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Then you'd worry about accidently walk away from the Prius without shutting it off.
  9. Mendel Leisk
    42,345
    I've never heard of a car that will automatically lock itself if you just park and walk away. Our Prius definitely doesn't.
  10. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Bad idea. What about the case where your key fob battery is dead and you accidentally leave it inside the car? You'll be locked out. The key is "out of range" because it can't respond.
  11. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    That's like asking why we should carry a spare tire because if two tires go flat you're still out of luck. You can't prepare for every possible eventuality.
    The car comes with two key fobs. Doubtful that both batteries run out at the same hour while both inside the car. What you describe is an edge case. Just because something might happen once in a blue moon is no reason to deny users a convenience every day. There is no technology that can fully prevent human fallibility. Just learn not to forget your keys, or have a spare somewhere. If you manage to forget your keys inside the car and the battery happens to die right at the moment they are inside the car, well, stuff happens.
    tanasit likes this.
  12. speedydevon
    speedydevon Junior Member
    San Jose
    So a while back I was looking to get a new Prius that did not have the proximity keys. I did some research and came up with this as a solution:
    Welcome to Advanced Keys
    Sadly I cant speak on how well it works, as the kit was stolen out of my car before I was able to install it! However I talked to the manufacturer as well as scoured some forums and it sounds like a pretty solid solution.
    I am planning to purchase it again to install in my 2012 PiP as I like the idea of self locking. Also the card key would be nice for going to the gym or the beach since its water proof and still would be able to unlock the car.
  13. lensovet
    2,615
    496
    Burlington, NJ
    Current gen priuses don't require any mods and allow you customize this feature via the display
  14. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Ummm.... 2010-2011 Priuses don't come w/a color touchscreen LCD unless you get nav. And AFAIK, even on those, you can't turn on/off the auto-lock in D and auto-unlock when in P behavior. You've got to use Techstream or some other device to send the necessary CAN bus messages.
    The feature of being able to customize many of the settings outlined in Things that can be customized | PriusChat yourself only started w/model year 2012, where Prius liftbacks once again started coming w/color LCD touchscreens.
  15. lensovet
    2,615
    496
    Burlington, NJ
    Right, that's I meant by current gen. Perhaps a better wording would have been to say all Entune-enabled Priuses. Regardless, we're in the PiP forum, which does have this feature :)
  16. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
  17. bisco
    52,855
    that fob looks uge!:eek:
  18. lensovet
    2,615
    496
    Burlington, NJ
    Tesla apparently does this on their cars. Mildly disconcerting as you want to make sure it actually locked lol.
  19. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    Isn't it pretty obvious with those door handles popping out when it's unlocked? :)
  20. lensovet
    2,615
    496
    Burlington, NJ
    Door handles pop out when you approach and when the doors are opened from the inside. They retract even when the doors are unlocked. Though it would be hard to open the doors even if the car is unlocked when the handles are retracted, lol.
