Auto mode for heat & A/C question
Discussion in 'Gen 3 Prius Main Forum' started by 4rpr15, Oct 1, 2015.
  1. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Makes sense - remember that heat rises, so you put it in low, and the warm air being lighter than the denser, cooler air, will tend to move up! (basic Physics!) ;)
    4rpr15 and dorunron like this.
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Not sure about your Prius, but on our 2013 Model Three there is a button on the flying bridge that has a couple of arrows and the defrost symbol. If you push that button the system will change the flow from one location to the next. It is another one of those items that can be overridden such as I described earlier ie: fan speed, recirc, etc.
    When ever you override part of the system it will stay over ridden UNTIL you hit auto again. Once you hit auto, everything will revert back to the default settings.
  3. qdllc
    qdllc Senior Member
    1,377
    400
    Remember...HEAT RISES. ;)
    4rpr15 likes this.
  4. dorunron
    3,318
    1,105
    Houston, TX
    yup, and cold air falls... like Wil said "basic physics".
    4rpr15 likes this.
  5. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Makes sense !
    MotoG3 ?
  6. Tideland Prius
    16,681
    The idea is that heat rises so you heat from the bottom and results in more uniform cabin temperature (as opposed to your face and chest area bathed in warmth while your legs and feet are cold). In addition, if your feet is warm, you feel warmer and you can operate the pedals better (i.e. safely).
    4rpr15 likes this.
  7. 4rpr15
    1,056
    375
    WI
    Tonight we drove around for an hour. The A/C light never turned off. The temp inside was 75 and after an hour it definitely felt like it was 75 inside. What gives? Auto Mode isn't just for an A/C setting ....is it?
    MotoG3 ?
    JTM2955 likes this.
  8. 4rpr15
    1,056
    375
    WI
    If that's how it's supposed to be I guess ...so be it. But you would think the A/C light would turn off.
    MotoG3 ?
  9. Tideland Prius
    16,681
    The light doesn't turn off. If the light is on while in AUTO, it means that the A/C compressor is controlled automatically and will cycle on/off as needed. A/C doesn't mean cold air, it just means conditioned air. In the summer, that air is conditioned in the form of temperature. In cold, damp weather, the air is conditioned in the form of humidity control (it dries the air so that your windows don't fog up).
    If your AUTO light is off and the A/C light is on, then you're "permanently" running the A/C compressor. And likewise, if the AUTO light is off and the A/C light is off, you're keeping the A/C compressor off "permanently".
    AUTO with A/C light off means you want the car to run in AUTO and never use the A/C compressor (so in the summer or in warmer temperatures, the fan speed will increase to offset the fact that the air temperature coming out of the vents is warmer than it would be if the A/C compressor was running)
    breakfast and 4rpr15 like this.
  10. 4rpr15
    1,056
    375
    WI
    Gotcha the average person wouldn't think about it that way, but this sheds some light into how it functions. Thanks
    MotoG3 ?
  11. bisco
    52,863
    if you change the air flow while on auto, doesn't auto shut off?
  12. 4rpr15
    1,056
    375
    WI
    Nope I tried changing the airflow from floor to cabin and it stayed on. I would rather have Auto do its thing.
    MotoG3 ?
  13. JTM2955
    JTM2955 Active Member
    475
    185
    Right, the Japanese engineers do not want warm air in the driver's face. Even if the A/C lamp is ON, it may only be cycling on oh so slightly ( its called duty cycling; it runs the compressor on and off many times a second; more on than off increases compressor speed, less on than off slows compressor speed). The HVAC controller computer looks at humidity, outside temp and sun load, interior temp. It then says, to get to the operator selection what needs to be turned on and off.
    Its a very sophisticated system, as I said before. If you don't want A/C just turn or put the button off. It will still try to get to target temp.
    And for the rest of us, it's not a bad idea to cycle through your different modes to exercise those HVAC doors, say once a month. They need to move, just to keep all of them working.
    My Recirculation door will do a "click click click" noise at times. A simple push of the button cures it. Then, I push it again and no clicking. But eleven years of almost daily use, I am not complaining. JTM
    4rpr15 likes this.
  14. 4rpr15
    1,056
    375
    WI
    Well said, thanks.
    MotoG3 ?
  15. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Nice thread about the sophisticated operations of Prii life support systems (a.k.a. Auto A/C). Discovered a lot of stuff I was rather vague about and will be trying in damp old London during my commutes this winter.
    Thank you, everyone!
    SM-G900F ?
  16. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Remember - It's not the heat, it's the humanity... :p
  17. RRxing
    2,564
    1,842
    NEPA
    For what it's worth, I just leave everything in Auto (including the A/C button) the year round and just adjust the temperature as necessary.
  18. Mendel Leisk
    42,355
    Through summer I use mostly roll-the-windows-down Mode, either a bit, or more, or fully, depending on speed, temperature, etc., with ventilation system shut right off. At high speeds, I'll turn on the vent system, roll the windows right up, or leave them slightly cracked. Very occasionally will use A/C. You do want to use A/C once in a while, to keep the oil circulated.
    On cooler days, or getting into wet and chilly winter, I'll roll up the windows and run mostly Auto with A/C off, if it's raining and fogging up I'll set mode to heat/defog. The latter kicks in the A/C surreptitiously, off and on, regardless of how you have the A/C button set. If it's a lot of bodies piling into the car with wet clothes, rain really coming down and the cabin getting overwhelmed by humidity, I'll expressly turn on the A/C. I'll try to run the last few block before shut down without A/C, to give it a chance to clear humidity of the chiller unit (not sure of the correct name).
    #58 Mendel Leisk, Oct 3, 2015
    Data Daedalus and 4rpr15 like this.
  19. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    That would be the evaporator, a heat exchanger in which refrigerant evaporates to extract heat from the air (thereby condensing water from that air).
    A last few blocks without refrigeration might not clear the residual condensation in cool rainy weather, but on a hot day should help.
    The programming of the "AUTO" mode makes smarter decisions than the average human operator most of the time, but occasionally it does annoying goofy things. For example, it sometimes switches unexpectedly to unwanted heat on slightly warm days when I choose to use the compressor sparingly. It needs a specific HEAT button so heat can be positively shut off, the same way AC can be (except in defog mode).
    #59 CR94, Oct 3, 2015
    JTM2955 likes this.
  20. JTM2955
    475
    185
    For the most part, I leave mine at 71 and roll with it. Cold days, I will raise it to 75. If the wife is with me, I add more fan for her.
    4rpr15 likes this.
