Auto start when temps are high
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Unproductive1, Feb 20, 2017.
  1. Unproductive1
    Unproductive1 New Member
    TBD
    Hi guys my first thread starting post here.
    I tried searching but couldn't come up with anything exact.
    I'm going to be installing an alarm and it has the feature of auto starting the car when the temperature sensor hits a set point (I think the max set is 130F but says it can do 10 deg increments below that). Its a probe that I can place anywhere I want to for checking the temp so it's not using any existing sensor on the car.
    Is there any help to the traction battery life if I use this function?...Or will I just be wasting fuel/charge?
    Thanks
  2. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    I assume this is while being parked to keep the interior from getting very hot?
    So, yes it will use/waste fuel and because you are stationary and using the A/C, the battery will cycle a lot. There is not much you can do about it.
    Some of the higher specs Prii have an option to run the A/C for a few minutes to cool down. But you only use that just prior to driving because it only uses the battery and won't work when the battery charge is low.
