Autocross Mods
Discussion in 'Gen 3 Prius Accessories and Modifications' started by toyotechwv, Apr 6, 2016.
  1. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    What's your toe setup?
  2. toyotechwv
    toyotechwv Toyota Technician
    474
    254
    Princeton, WV
    I'll typically run about a quarter degree of negative toe, it helps with turn-in.
    SM-G900V ?
    RightOnTime likes this.
  3. trip1027
    trip1027 Member
    106
    27
    wyoming
    Do u use Apexi accel mod
    SM-N920V ?
  4. toyotechwv
    474
    254
    Princeton, WV
    As in the add on throttle controller? Nope...unless you wanna buy me one
    SM-G900V ?
  5. trip1027
    trip1027 Member
    106
    27
    wyoming
    I like mine
    SM-N920V ?
  6. toyotechwv
    474
    254
    Princeton, WV
    How much different is the feel over using Power mode?
    SM-G900V ?
  7. trip1027
    trip1027 Member
    106
    27
    wyoming
    Quite a bit after driving all day using the power on the controller and then going to my wife's 2011 and use her actual power mode button you can really see the difference
    SM-N920V ?
    Starbrand likes this.
  8. toyotechwv
    474
    254
    Princeton, WV
    How much does it cost?
    SM-G900V ?
  9. trip1027
    trip1027 Member
    106
    27
    wyoming
    I found mine right around $100
    SM-N920V ?
  10. toyotechwv
    474
    254
    Princeton, WV
    Wow now that's not bad. I'd actually consider it for that price. Will have to see how it affects class rules though. You have a link or pic of what I'm looking for?
    SM-G900V ?
  11. trip1027
    trip1027 Member
    106
    27
    wyoming
    But u get to full throttle almost instant
    SM-N920V ?
    It adds zero horseys
    SM-N920V ?
    APEXI SMART THROTTLE CONTROLLER
    SM-N920V ?
    SM-N920V ?
    U got cold air intake or exhaust?
    SM-N920V ?
    toyotechwv likes this.
  12. toyotechwv
    474
    254
    Princeton, WV
    Nope, neither. Not allowed in class I'm competing in. Well actually I could change exhaust from cat back but the cost doesn't justify the reward. I'll have K&N drop in filter, TRD rear sway bar, and tires. Koni FSD'S are on the list but need more $$.
    SM-G900V ?
  13. trip1027
    trip1027 Member
    106
    27
    wyoming
    Have you ever tried your car out without the baffles on your intake if not then you should try it just as a test run
    SM-N920V ?
  14. toyotechwv
    474
    254
    Princeton, WV
    Not sure what you're referring to here.
    SM-G900V ?
  15. trip1027
    trip1027 Member
    106
    27
    wyoming
    SM-N920V ?
  16. toyotechwv
    474
    254
    Princeton, WV
    I've had it off before but not in autocross. Not allowed in my class to modify any part of the intake minus filter. Also with that removed you actually draw in hotter air. I plan to eventually install the Injen intake and plumb it under the headlamp for true cold air. But that will be when I move to a different class.
    SM-G900V ?
  17. granTORRESmo
    237
    648
    Norcal
    I have coilovers, what class would I fall into?
  18. toyotechwv
    474
    254
    Princeton, WV
    You would be in FSP I believe.
    SM-G900V ?
    granTORRESmo likes this.
  19. granTORRESmo
    237
    648
    Norcal
    Hey. Do you still have an inverter cooler? Is it necessary for autox? Do you upgraded break pads? And what sticky tires do you recommend for 15 stock rims?:)
  20. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    *subscribed*
