Automated Touch Screen Questions
Discussion in 'Gen 2 Prius Audio and Electronics' started by Virodeath, Feb 8, 2006.
  1. Virodeath
    Virodeath New Member
    102
    NW Indiana
    Hey guys trying to wrap up my system components and have some questions. I would like to mount a powered screen in the slot under the radio but I am not sure what kind of clearance it needs to have to extend all the way up. Has anyone done this or can rec. a good screen or dim. I should be looking at?
    Also we are planning on doing some traveling this summer and was thinking of a roof mount screen for the kids to watch in the back. Has anyone done this or know if it can be done? Not sure how you would attach and get power to it..
    Thanks in advance!
    Viro
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
  3. Virodeath
    102
    NW Indiana
    I had read that forum and it looks like Presto is looking for the same thing I am..? What info. do you think I can use cause I seem to be missing it...
    Viro
  4. efusco
    19,891
    1,192
    Nixa, MO
    Well, maybe I don't understand what you're looking for. Presto has a screen mounted in the slot under the radio that's up and functional....I thought that's what you were trying to do.
  5. aaf709
    3,862
    2022 Prius Prime
  6. Virodeath
    102
    NW Indiana
    Efusco his install is a manual pull out monitor, I was looking for a powered one but understand there may be a clearance issue with the screen when it flips up and the bottom of the radio area hitting not letting the screen fully flip up. Also would be cool if you could keep it hidden behind the stock door that is there.
    Aaf709 thanks for the great link, can you tell me are those the stock headrests you had monitors installed into or are they larger after market ones? Did the monitors have install instructions for stock headrests or did your installer wing it? Anyone know where I can see more info on the Toyota ones listed by Shawn7? Google is bringing up some billion hits and haven't found them yet.
    Thanks again for all the help!
    Viro
  7. aaf709
    3,862
    2022 Prius Prime
    I didn't do it. I suggest you join that topic and maybe someone can give you more information. I know that it's possible. If it were me, I'd stick with ones on the headrests.
  8. koa
    koa Active Member
    980
    45
    Hawaii
    My dealer had the DVD headrest screens as an aftermarket option. Try calling your dealer to see if they offer it also.
