Automatic Braking Feature
Discussion in 'Gen 5 Prius Technical Discussion' started by rschlegel, Feb 24, 2023.
  1. rschlegel
    rschlegel Junior Member
    Raleigh, NC
    Exactly what is the "automatic braking" feature that's an option on the new 2023 Prius LE and SE? Is that only used with the parking assist feature? Does that apply the front and rear brakes when the vehicle radar detects the car is too close to an object in front of it? Or does it have something to do with the emergency brake when parking?
    #1 rschlegel, Feb 24, 2023
    52,862
    the first one
  3. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    Which 2023 Prius do you own?
  4. Trollbait
    12,831
    Doesn't the gen4 have automatic braking?
    Not all cars with auto braking have it on rear.
    I have never seen automatic braking or AEB refer to the parking brake.
  5. bisco
    52,862
    I don’t, how about you?
  6. Tideland Prius
    16,681
    Taken from toyota.com
    Front and Rear Parking Assist with Automatic Braking (PA w/AB) *
    Ok, it looks like they renamed "Intelligent Clearance Sonar" to PA w/ AB lol.
    This feature is a low-speed feature that uses the ultrasonic parking sensors around the car. It will do the usual "beeps" like parking sensors have done for decades but add a detection feature that will stop the car (yes brake) if it senses you're getting too close to an object in front of or behind the car as you are travelling forwards or backwards respectively. On the Gen 4 Prius (2016-2022), it also included side detection where it would plot a trajectory of the vehicle if it detected something from its side-facing sensors in the front bumper (e.g. a pillar or passing traffic) and if you made a turn that the car deemed might put out in a collision course with the object, it will warn you (but won't brake since it's not directly sensing it but just plotting trajectory).
  7. MaxT
    MaxT Junior Member
    27
    45
    Georgia
    2023 Prius
    It works well.
    After my test drive was parking and there were some bushes in front of me and as I was getting ready to brake, the car stopped. I looked at the salesman and we both said, auto brakes work!
  8. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    • It is not radar.
    • It is sonar (ultrasound).
    • It will brake automatically if your front or rear bumpers are about to hit an object.
    • Parking sensors need to be turned on.
    • Parking assist does not need to be turned on.
    • On Gen 4, ultrasound is only available on Limited.
    • On Gen 5, so far, ultrasound is available on all models, including LE and SE, even if it does not show as an option on the window sticker. Hopefully, it will stay that way.
  9. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    So there is no side detection on 2023?
    Gokhan likes this.
  10. Gokhan
    6,714
    2,672
    Paramount CA
    Yes, there is. There are sensors on both the front and rear sides. However, there are no sensors in the middle sides, but then the car is not designed to be able to move sideways.
    daisy555 likes this.
  11. fuzzy1
    10,711
    As a pedestrian earlier this year, I had a parking lot encounter with a Tesla that needed a middle or better rear side sensor.
    I was walking across the parking lot behind it as it seemed to be turning to pull forward into a parking space, when it suddenly stopped, reverse lights came on, I froze, and it it started reversing into a different space in the other row. Turning sharply with its front wheel now aimed aim at me, I was readying to punch the driver window when he finally stopped, turned my way, look startled at a human standing within arm's reach, and asked if he could help me. He didn't realize that I had been standing stationary there the entire time he was backing up, where I'd have been knocked over by his front quarter panel and run over by his front wheel.
    He had to have seen me next to my car, waiting to cross the lot, when he initially rolled past me. But didn't register a human who would be at risk when he changed directions.
    #11 fuzzy1, May 13, 2023
    Tideland Prius likes this.
  12. Gokhan
    6,714
    2,672
    Paramount CA
    Yeah, you need to be a defensive pedestrian as well as a defensive driver and anticipate foolish behavior.
    RCTA on my Gen 4 detects walking pedestrians. BSM detects bicycles. The ultrasonic parking sensors only work within about a couple of feet from the sensor. Gen 5 has front radars as well and has FCTA and safe-exit features.
    Toyota is really good at packing all available safety features. Tesla seems to be more interested in quasi-automated-driving than safety features.
  13. daisy555
    1,729
    716
    CT
    Thank you….moving sideways is not something I’m interested in doing. : )
    Gokhan likes this.
  14. Gokhan
    6,714
    2,672
    Paramount CA
    There are twelve ultrasonic parking sensors—one on either side of each corner, two on the front, and two on the rear.
    I like parking close to the parking-structure columns at the university so that I am away from the car next to me, and the ultrasonic parking sensors help a lot. We also get a significant parking discount and unrestricted-zone parking for plug-in vehicles.
    On my 2020 Prius Prime XLE I had, I relied on the reverse camera alone, as it didn't have parking sensors like on my 2021 Limited, which you shouldn't because it is highly misleading for the corners, and I ended up hitting one of the corners of my rear bumper. The ultrasonic parking sensors would have prevented that.
    #14 Gokhan, May 13, 2023
  15. Tideland Prius
    16,681
    I’m not sure as it’s not explicitly mentioned. There are sensors on the side (front and rear bumpers) for scanning parking spaces and for the IPA but I don’t know if that feature carried over to the new system.
    The old Prime with ICS could intelligently map out an object you passed and warned you about it even though it can’t physically detect it. That was an advantage over the competition.
  16. Gokhan
    6,714
    2,672
    Paramount CA
    I don't think anything changed from Gen 4 to Gen 5 with regard to parking sensors—same twelve ultrasonic sensors and mapping scheme have carried on to Gen 5.
    However, looking at the owner's manual, the path estimation is only mentioned for "intuitive parking assist object-warning function (vehicles with advanced park);" so, perhaps models without the advanced-park package with side-mirror cameras do not have the path-estimation feature enabled.
    #16 Gokhan, May 14, 2023
  17. GeoJ
    GeoJ Active Member
    225
    203
    United States
    My understanding is that the parking sensor can be turned on/off but not adjusted for sensitivity or volume of warning, and that if turned off the auto braking that comes with this feature is also turned off? Is this correct? I find the parking sensor is overly sensitive - for example, for my charging cable to reach I need to pull in close to my house and it screams at me every time I do this, also screams virtually every time I park. So if my understanding is correct, I guess my options are to turn off the parking sensors (and auto braking) or to just live with it. My preference would be to leave the braking on but turn the warning off, so that if I truly was going to hit something front or rear it would brake, but not warn me every time I get close (which is every day I drive the car). Anyone with thoughts on this, appreciated!
  18. daisy555
    1,729
    716
    CT
    Hopefully there is a solution. I’m really surprised there isn’t a way to control the volume. That must be super annoying.
  19. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    You can get an extension cord like I did to charge mine where I live. Have an older home but the plugs are in the front part of the garage and the 24 foot power cord is not quite long enough. It's also nice to have when traveling in case you need it.
  20. GeoJ
    GeoJ Active Member
    225
    203
    United States
    So I checked into this and believe you can turn down the volume. I'm still checking but think you can also turn off the intuitive parking assist sensors, but leave on the auto braking at slow speed (which is a different feature). I've not decided yet if I'l turn it off, have started by turning in down.
