Automatic Headlights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by hawkmoon77, Jul 6, 2009.
  1. Yes - It is worth the $50 dollars plus labor for all of that edded convenience.
    500 vote(s)
    83.9%
  2. No - I don't need another computer to turn on a switch for me when it gets dark.
    96 vote(s)
    16.1%
  1. motoleon
    motoleon Junior Member
    48
    16
    spain
    Thanks. Here, in Europe (Spain), it is already wired to L7.
    Only i have put wire to pin 28 and ground and...automatic lighting.
    THX everybody. (I have to publish that in mitoyotaprius chat.)
  2. jayvee
    jayvee Member
    341
    89
    WA
    Lucky guy! Thanks!
  3. dwhutch
    dwhutch New Member
    Los Angeles
    That's for sure.
  4. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    That is brilliant! Does anybody know where i can find this L7 connector on a right hand drive car?
  5. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    Although this of course will work (and I do it all the time), to get an insurance discount for DRL's they can not be defeated - that is they must ALWYS go on when the car is running. So, will the proposed solution work?
    Thanks.
  6. jayvee
    jayvee Member
    341
    89
    WA
    The "proposed solution" being discussed is not for DRLs, which are on all the time - it is for Automatic headlights, which turn on automatically at night, and shut off automatically during daylight. Rachaelseven's post was intended to remind someone that the lights are already auto-off in every car - so they can be used as DRLs, in a sense. And since they can be shut off, I wouldn't think you can get an insurance discount for using regular headlights that way. It would be kind of like telling an insurance company you have an alarm system, which consists of you sitting up all night watching the door...not exactly what they intend...:)
  7. dchev
    dchev New Member
    26
    17
    Charlote, nC
    Can anybody that has Generation 3 Prius with auto headlights/DRL to post pictures, so we can see how headlights look?
    I believe that auto headlights go in pair with DRL-at least this is the way Toyota has them in other models....
    Thanks!:)
  8. PixelRogue
    485
    86
    US
    Your mods look great. What did you use to secure the felt? Just cut and stick? Also, where did you mount the radar detector - pictures?
  9. Flaninacupboard
    1,297
    213
    Midlands - UK
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I just got my 545T Night Lite today & just came across this thread. Mine is going into a 06 GenII. I have a few questions:
    1) Anyone know if the GenII is pos or neg switched?
    2) Anyone install this in a GenII & have the correct wires/pins I need to tap into?
    3) Can the OEM light sensor be used instead of the sensor that comes with the kit?
  11. sdetweil
    sdetweil New Member
    84
    texas
    does the Gen III mod II have the light sensor? there is something on the right side of the dash, but doesn't look like a sensor to me.. more like a plug..
    sam
  12. dwhutch
    dwhutch New Member
    Los Angeles
    That is a sensor. All the Gen III's have it. The cover is hard to see through but at some angles you will the circuitry inside. There are two sensors in this package the infrared heat sensor is used by the AC. The light sensor, which is not connected in US cars, is used for Auto head lights and dimming the dash panel based on lighting conditions.
  13. sdetweil
    sdetweil New Member
    84
    texas
    thanks, I will continue on with the mods for auto lighting then..
    Sam
  14. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I'm interested in jayvee's mod and have a couple of questions.
    Is the sensitivity adjustable?
    Where to purchase the CN stalk?
    Are the stalks interchangeable with other US Toyotas? If so what year/model.
  15. sdetweil
    sdetweil New Member
    84
    texas
    no
    I looked on discounttoyotaparts.com
    see here for the part numbers
    http://priuschat.com/forums/gen-iii.../64812-automatic-headlights-9.html#post953788
    don't know, but suspect not.
    Sam
  16. jayvee
    jayvee Member
    341
    89
    WA
    The sensitivity for turn on/off of the headlights themselves is not adjustable (at least not that I can find.) Only the day/night mode of the instrument panel, NAV, etc. is adjustable through dealer-programmable settings - see Sec 6.2, page 591 of the owners manual. However, it's possible that this may also control the headlight on/off when in true "Auto" mode - I haven't confirmed this (never thought to check). I think they may be "linked".
    The cheapest I found the stalk is on parts.com ($93). But toyotapartsoutlet.com often has free shipping promotions (as they do right now, for August).
    The stalk also appears to be used on the Rav4, Tundra, and Sequoia - not sure what else, or which country (parts sources don't identify the country of use) but a dealer should be able to tell you for sure, based on the part number.
  17. cproaudio
    2,401
    762
    CA
    How do Canadians adjust the sensitivity? Where's Tideland when you need him?
    Is the CN stalk plug and play? Is it a direct replacement?
    I have the V with ATP. is 84140-07141 the right part?
    When I was searching for 84140-07141 I often get results for Highlander, RX350, IS250 and IS350. I sometimes also get 84140-48200 replaced by 84140-07141 as search result.
  18. jayvee
    jayvee Member
    341
    89
    WA
    Other than the wiring changes described in the rest of this thread, there were no other mods to install the Canada stalk on my US IV. I can't imagine the V is any different. The connectors are the same; it's just the wires/pins that may not be in place. I believe that the 84140-07141 may indeed have been superceded by the 84140-48200. A quick call to the dealer parts dept will confirm this.
  19. sdetweil
    sdetweil New Member
    84
    texas
    sorry, anyone have a link to pulling the top glovebox and ecu box behind it?
    and I will be working on the radio (w/rear camera), fog lights & stalk change at the same time..
    sam
  20. albert1028
    albert1028 Junior Member
    To Jayvee,
    If i get the Canadian stalk which is also the stalk for other vehicle models here in the US. Do i just connect the following:
    L7,PIN21 TO I1,PIN4
    and
    L7,PIN28 TO SWITCH TO GROUND
    and install the stalk?
    Thanks!
