Automatic light control??
Discussion in 'Gen 2 Prius Main Forum' started by Springtime, Jan 7, 2006.
  1. Tideland Prius
    16,680
    <div class='quotetop'>QUOTE(scoot @ Feb 12 2007, 09:05 AM) [snapback]388912[/snapback]</div>
    You can retrofit rain-sensing wipers. Just check Sigma Automotive (dot com) and look under Prius
  2. hill
    9,038
    <div class='quotetop'>QUOTE(Panther87 @ Jan 7 2006, 07:22 PM) [snapback]185577[/snapback]</div>
    We got in on our 2004
  3. Tideland Prius
    16,680
    "Light Control System" = auto headlights = Cdn models
    "Automatic Headlamp Cancel System" = Auto-Off headlights = US models
  4. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    <div class='quotetop'>QUOTE(Snick @ Feb 9 2007, 06:39 PM) [snapback]387754[/snapback]</div>
    I miss the auto headlights also. I checked with my dealer's service dept. and they said it must be factory installed.
  5. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(tumbleweed @ Jan 7 2006, 03:38 PM) [snapback]185562[/snapback]</div>
    I thought all Toyotas had this feature, My 97 Camry had that too.
  6. Tideland Prius
    16,680
    <div class='quotetop'>QUOTE(TomorrowMatters @ Feb 18 2007, 11:36 AM) [snapback]392451[/snapback]</div>
    Nope. Up here in Canada, the Yaris (both versions), Corolla, Matrix and RAV4 don't have it. Base Highlanders don't but Limited models do.
  7. scoot
    scoot Member
    125
    <div class='quotetop'>QUOTE(Tom 6850 @ Feb 17 2007, 11:17 AM) [snapback]392059[/snapback]</div>
    Yeah, that's probably BS. Mercedes was notorious for telling people that you had to have things as factory options. Not the case with MB at least... Someone just needs to figure it out, like the JDM dipping mirrors, etc.
  8. razzledazzlebee
    razzledazzlebee New Member
    114
    Seattle area
    I, too, was EXTREMELY disappointed about the Prius not having the Auto-Light feature. I traded in my '05 Corolla (which has that feature standard, even on the basic CE model) and my husband has that feature on his 05 Matrix. I was under the impression that's a standard Toyota feature, and did not find out it's not on the Prius until after I bought the car. I may have considered buying the car in Canada just for that feature (I'm only 30 mins from Vancouver), but I didn't know that wasn't included. In the Corolla brochure it's not even listed although it's standard....
  9. Tideland Prius
    16,680
    <div class='quotetop'>QUOTE(razzledazzlebee @ Feb 21 2007, 06:41 PM) [snapback]394323[/snapback]</div>
    Yeah I'm questioning that lol. Since when did the Corolla/Matrix ever get automatic headlights? Our Canadian models don't have them.
  10. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    So, do we have any Canadians that can find out if the sensor on the dash for auto headlights can be used in a US model Prius to automatically control the on/off function of the headlights? If not, or too complicated, does anyone know of an aftermarket system that can be used? Sounds like a job for Coastal...
  11. mrpickles
    mrpickles New Member
    <div class='quotetop'>QUOTE(ilusnforc @ Mar 26 2007, 04:50 PM) [snapback]412544[/snapback]</div>
    I also would like to add this feature. Has anyone figured it out yet ??? Aftermarket or factory, it can't be too hard. I was hoping someone already has done it and could advise..
  12. chutneypopcorn
    chutneypopcorn New Member
    36
    <div class='quotetop'>QUOTE(Tom 6850 @ Feb 17 2007, 01:17 PM) [snapback]392059[/snapback]</div>
    Hey that's weird, my 2007 Prius, pkg 6 (fully loaded) Touring has the auto lights feature, or am I hallucinating...Pg 110 of the manual explains how to use it. Position 3 on the headlight turn switch is the
    "Auto" position...Please correct me if I am wrong.
  13. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    You may have gotten a Canadian model. I'm pretty sure it even says in the owners manual, where you describe the instructions for use of the Auto setting, that it is a Canadian feature. Can you locate the sensor on the dash? I wonder how much it would cost (assuming it's completely plug-and-play) to add the sensor and stalk with auto position and whatever else is needed. Anyone know of a Canadian Prius salvager?
    Edit:
    Bagh... I just remembered... I think HID lights were not available in Canadian models because of the Auto headlight feature. That may cause some incompatibility problems.
  14. chutneypopcorn
    36
    <div class='quotetop'>QUOTE(ilusnforc @ Apr 9 2007, 08:53 PM) [snapback]420603[/snapback]</div>
    That's interesting, didn't know it was luck of the draw getting a "canadian" model or otherwise. I suppose I am fortunate, eh ;)
    Doesn't say anywhwere in the section for headlights that the auto or DRL is a canadian feature. And yes, there is a sensor on the dash that the salesman pointed out to when I specifically asked him about the auto lights feature. However, on Pg 112 there is a separate section for Headlights and turn signals (without auto light control system).
  15. Frank Hudon
    Frank Hudon Senior Member
    4,147
    there should be two sensors on the dash, one for the climate control system and one for the auto headlight system. If you have the "auto" feature.
  16. Tideland Prius
    16,680
    <div class='quotetop'>QUOTE(chutney @ Apr 9 2007, 08:38 PM) [snapback]420590[/snapback]</div>
    There are TWO sensors (domes) on the dash, not one. How many do you have?
  17. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 9 2007, 10:05 PM) [snapback]420644[/snapback]</div>
    In the US, we have one, and a knock-out for the hole for the second. One would knock out the plastic and put the light sensor in for the auto-headlights. We're definitely less equipped in the US.
  18. Tideland Prius
    16,680
    <div class='quotetop'>QUOTE(htmlspinnr @ Apr 9 2007, 10:18 PM) [snapback]420653[/snapback]</div>
    I know but chutney said he had two on his US-spec Touring.
    And I wouldn't say you're less equipped. You have HIDs and leather option for less money. Not to mention the Touring package.
  19. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    I talked with my service dept and they said auto headlights cannot be added to our 2007, it must be factory installed. On my dash on the left front there is a sensor, which I beleive is for the auto headlights. If the sensor is there why can't it be added?
  20. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(Tom 6850 @ Apr 10 2007, 04:46 AM) [snapback]420712[/snapback]</div>
    the sensor you have is for the climate control not for the auto headlights.
