automatic rear view mirror occluded and malfunctioning
Discussion in 'Gen 3 Prius Technical Discussion' started by peter, Nov 15, 2011.
  1. peter
    peter Junior Member
    29
    gothenburg, sweden
    I have used a priux-III for a year now with mixed feelings. But one item really annoys me, the rear mirror automatic dimming does not function.
    Well it does sort of function, it dims the mirror when light falls on the sensor. Light coming from inner lights. But headlights from vehicles behind me are occluded by the horisontal divider between the read windown.
    Try it yourself, measure the height of rear mirror sensor, and the height of the divider. Then figure out why it does not react on cars behind you !
    Antone that has got a fix ? Turning the mirror upside down would make the sensor come into the view of vehicled behind. Is that possible ?
  2. denster1
    denster1 Junior Member
    Annapolis, MD.
    I agree the automatic dimming function is subpar. I recently had window tinting applied to my car and a byproduct of the tinting application was dramatically reduced glare from following vehicle headlights.
  3. Tideland Prius
    16,683
    Remember that it's not the mirror's fault. The mirror is the same mirror used on most cars (Toyota, Nissan, Honda, GM, Chrysler etc). It's the rear spoiler that's getting in the way of the light sensor on the mirror. On the Gen 2 Prius, you could flip it upside down and it works perfectly. Unfortunately, you can't do that in the Gen 3. There's not enough clearance.
  4. peter
    peter Junior Member
    29
    gothenburg, sweden
    Today my dealer replaced the mirror ( they refused to discuss other solutions until they are convinced that it's not a faulty mirror)
    I'm fairly convinced that the new one won't work, and if so i'll try to convice the dealer to install a manual mirror.
    I'll report the outcome.
  5. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    "It's a feature, not a bug."
  6. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I've had the auto-dimming mirror in both of my Gen 2 Prius, and never have had the problem you are experiencing. I find that most cars' lights are blocked by the design of the hatch, and higher vehicles like trucks cause the mirror to function as designed if they get to close or have high beams on.
    If you wind up using the standard mirror, try to hang on to the auto-dimming one. You may be able to sell it on ebay. I plan to add one when my PIP comes in next year.
  7. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    I have the same issue with my rear view mirror on my IV. I dimmed my dash lights and it seemed to have solved the problem. With the dimmer dash lights, the auto dimmer seems to work.
  8. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    Because you are fortunate enough not to have the same height as OP?
    I am fairly tall and the divider doesn't give any problems for me.
  9. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I don't have a Gen 3, but can the mirror be moved up or down? It might help. I'm not talking about tilting it.
    I discovered this one of my previous cars w/auto-dimming mirror, only because someone else posted about it. Usually the best way was to grab the mirror w/both hands to move it up/down.
  10. rogerv
    1,639
    317
    The OP didn't indicate that his height was the problem, nor did he say how tall he is. I'm just over 6' and this just hasn't been a problem for me. Maybe where he lives people use highbeams more?
  11. sailorbee
    sailorbee Junior Member
    Ballston Spa, NY
    I just double stick taped a piece of exposed film negative (I know how many people actually have that sitting around) cut to the size of the sensor to the sensor. This changed the ratio from front light sensed to rear light with the end result being, AUTOMATIC MIRROR works just like the one in my Prius2.
  12. peter
    peter Junior Member
    29
    gothenburg, sweden
    The mirror cannot be moved up/down, neither can it
    be turned upside down on a genIII prius ( european version)
  13. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    It moves up and down on mine, though it's not easy - I had to adjust it otherwise it gives me a huge blind spot, especially for pedestrians.
  14. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    The auto dimming mirror works as always for me. When it dims, the reflection turns green. I know it works because when a car is far away, their headlights are white. When they get close, the lights turn green. I thought my rear window has green tint. When I turn off the auto dimmer, the lights got brighter and back to the original color.
  15. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    I had the same issue wth the mirror until I dimmed the dash lights. I had the lights turned up to max all the time. By having them dim at night, the rear view mirror dims the headlights on my rear. :mod:
  16. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    My UK based Gen III mirror does allow some limited movement up and down on a link arm. I have it jammed up as high as it can go and it works well there.
  17. peter
    peter Junior Member
    29
    gothenburg, sweden
    I do have 35mm negatives :) Do you stick it on the rear-facing sensor ?
  18. sailorbee
    Ballston Spa, NY
    Front sensor on drivers side, it is about the size of a thumbnail
  19. peter
    peter Junior Member
    29
    gothenburg, sweden
    No effect whatsoever.
    In fact i can see the shadow of the spoiler on the lower half of the mirror.
    I'll have toyota replace the mirror with a manual one.
  20. randalla
    randalla Member
    370
    Lexington, SC
    I do a lot of highway driving in the dark hours in my 2010 model 5 and have been very dissappointed with the performance of the Homelink mirror when headlights appear in the mirror. I realize that the spoiler is the most likely culprit of the poor performance but it has gotten to the point that I'm considering replacing the Homelink mirror with a standard OEM mirror. Does anyone know if there will be any mounting issues going from the Homelink to the standard mirror?
