Automatic temp spoofer available
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Tanilainen, Jun 12, 2023.
  1. BlueCoast
    BlueCoast Junior Member
    26
    New Zealand
    2014 Aqua
    Yes, I use Hybrid Assistant daily to observe all stages of engine operation. I asked if the spoofer will work with the Prius C / Aqua. I asked this because OP designed the spoofer to work with a gen 2 Prius. The Prius C / Aqua has the same engine operating procedures as a gen 3 but with the 1.5L engine of a gen 2.
  2. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    Third planet from the Sun
    The engine operation stages are the same. You can see this through the program.
    But the spoofer automatically works with a specific engine ECU. I believe that it uses certain levels of electrical parameters calculated for a specific ECU.
    These parameters may be different in different cars.
    In order not to harm your car, I would not recommend using a spoofer for the Prius C that is configured to work with GEN2.
    First, try manually selecting the resistances that simulate the engine sensor temperature.
