Aux input and iPod Touch/iPod Shuffle in Prius 2010
Discussion in 'Gen 3 Prius Audio and Electronics' started by pakitt, Oct 3, 2009.
  1. pakitt
    pakitt Senior Member
    2,173
    1,312
    Colorado
    I have tried to connect via the AUX input in my Prius 2010 to the iPod Touch and my iPod Shuffle (1st gen) headphone output jack and in both cases the volume output from the car stereo is low. It does not change much when raising the volume of the iPod to the max.
    Has any of you tried to connect their iPod connecting the headphone output to the AUX input and noticed the same issue?
    Do I need to use an adaptor or some other device to make sure that I can hear my iPod properly?
    Thanks for any help/info.
  2. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Had no problem with my Ipod the couple of times I tried.
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Used the AUX jack with iPhone OS3.0, iTouch 3.0, iPod classic - all work fine.
    You have to adjust the volume on the iPod for best sound - but the level can be adjusted very loud. If yours is not, and you have tried different devices (and are sure you turned up the volume on the iPod), you have a defective port/HU...
  4. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    What about USB like the HONDA INSIGHT has? Is there any configuration that will work the same?
  5. pakitt
    2,173
    1,312
    Colorado
    Did anybody else tried the AUX connection with the iPod Touch?
  6. bwilson4web
    15,595
  7. observing
    observing Junior Member
    16
    Baltimore, MD
    I use the AUX with my iPod Touch and have no problems with the volume. As rrolff wrote, adjusting the volume on the iPod should bring the sound level up to the radio's sound level. Try replacing the cable between the AUX jack and your iPod. I doubt that this is the problem, but it's cheap to troubleshoot a possible cause of it.
  8. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Are you sure the cable is all the way in?? If it is try a new one or hook the cable into something else like a surround system to see if it works well. Make sure you aux port is protected from dirt/debris. Basically I have a cord I leave in there all the time, that way I do not need to worry about dirt in the port.
  9. PeterP
    PeterP New Member
    Usually iPods (and Zune, etc.) do pretty well into the AUX, but you will still need to boost the volume from your normal listening setting. It's usually the smaller mp3 players (the ones with just 1 AAA battery) that have a problem and really need some type of preamp. Google Sound Shocker, FiiO, or Boosteroo and you'll find all sorts of info.
  10. pakitt
    2,173
    1,312
    Colorado
  11. toyoyo
    toyoyo New Member
    SE US
  12. pakitt
    2,173
    1,312
    Colorado
    I have received the Griffin Autopilot last week and tried and it works perfectly. I need to set it "high", otherwise low is not good enough (for me), otherwise it is wonderful.
    Now, if only the FM reception wasn't that noisy/full of pops and static....
    THANKS to "bwilson4web" for the hint!
  13. Carnutt
    Carnutt Member
    232
    23
    SW USA
    2018 Prius
    Can you tell me where the aux. port is?:confused:
    Thanks, in advance.
  14. pakitt
    2,173
    1,312
    Colorado
    Inside the central console compartment underneath the central arm rest - open it and at the bottom, at the back, next to the cigarette lighter socket (or I should say, power supply socket) there is the "AUX" input jack, covered by a soft plastic cover.
  15. Mark57
    2,945
    2,737
    OK
    Inadvertent post, please disregard.
