Aux Jack repair
Discussion in 'Gen 2 Prius Audio and Electronics' started by Berch1943, May 20, 2020.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    Hi all,
    I'm trying to repair the aux input. It has a bad input where the car won't recognize its plugged in. So I took it out and pulled apart the circuit board.
    My suspicion is one of these pins has a bad connection but I can't figure out which. I tested it by leaving it plugged into the car. When I press down the green box then it will seem to recognize.
    I also can't notice any loose pins when I push the green port down. But my guess are pins 1 and 3 on the edges have a bad connection just seeing how close to the edge they are. Any ideas? 20200520_203507.jpeg 20200520_203553.jpeg 20200520_203637.jpeg 20200520_203724.jpeg 20200520_203731.jpeg 20200520_203759.jpeg
    ydpplqbd likes this.
  2. dolj
    dolj Senior Member
    8,645
    4,394
    Wellington, New Zealand
    Inside the plug, there is a switch that is supposed to close the circuit when the plug is inserted. The switch has failed (open) and so the system never knows there something plugged in and therefore never allows the Aux to be selected. You need to bypass the switch and bridge the switch pins to make the circuit permanently closed.
    I hope that makes sense and helps.
  3. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    ^ what he said. When you plug in, the plug shank physically displaces a lever to close a switch and that (usually) grounds a pin that is normally unconnected. When the head unit detects the extra path to ground it knows to enable the aux input.
    Replace the jack itself, or replace the entire pcb module, or permanently ground that pin if you don't mind locking the system into aux mode.
    There is a small chance you can get the lid off of the jack package and correct the internal switch problem. I've never tried on one of these; only some pcb mount jacks are meant to open up, some are one-piece or welded shut. It would be tricky anyway due to size.
    This diagram (generic, scraped from elsewhere) may help:
  4. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    While the failure in time (fit) of a soldering is 5 a rarely used connector has 10 fit and a switch (in the plastic housing of the Jack a switch is included) has even 1500 fit. (Typical values from MIL-HDBK 217)
    So probably a problem with the Jack itself. If you'll open the plastic housing, maybe you'll find some dust between the contacts or mechanical parts. But be aware of any possible little spring set free while opening.
    You also could try to just blow some compressed air into the Jack at first.
    SM-G950F ?
  5. Berch1943
    Berch1943 Member
    146
    Arizona
    So something like soldering the resistor pins in parallel like described here?
    Aux audio input fault on Gen II Prius - A Cheap Repair that works (Part 86190-53010) | PriusChat
  6. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    I can't swear that circuit works the same as yours, but you're on the right track.
