Auxiliary battery happy voltage
Discussion in 'Gen 2 Prius Technical Discussion' started by Docholo, Feb 18, 2018.
  1. Docholo
    Docholo Junior Member
    23
    I drove about 800 miles over two days and the no-load voltage on the auxiliary 12 v battery is 12.72 volts measured right at the battery terminals with the leads off. This battery is about 5 years old.
    Is this a reasonable state of charge for this battery? The engine seems to be running a bit more than usual and the traction battery is above 75% full.
    iPhone ?
    52,767
    did you measure it after the surface charge wore off?
    it's hard to put a number on it. low 12's is getting iffy.
    there are a million reasons why the engine might run more. best thing to do is track your mpg's at every fill up.
    padroo and Raytheeagle like this.
  3. padroo
    padroo Senior Member
    2,763
    2,253
    What have the temperatures been?
    Raytheeagle likes this.
  4. Docholo
    23
    Outside temperatures have been between 45 and 78 F. (southern AZ and SoCal).
    iPhone ?
  5. bisco
    52,767
    southwest heat is hard on all batteries.
  6. Mendel Leisk
    42,253
    That sounds fine, but: 5 years old, I'd replace it anyway, leave on a high note.
    padroo likes this.
  7. padroo
    2,763
    2,253
    I always try to squeeze all I can out of a 12V battery and my wife says just change it. I started listening to her, that way I can never be wrong again. DAH
  8. Mendel Leisk
    42,253
    I hear that emergency vehicles, ambulances and the like, change batteries every two years. Overkill, acknowledged, but just a decision they've made.
  9. padroo
    2,763
    2,253
    The contract for my whole house generator wants you to change the battery every four years, mine only lasted three.
  10. Prodigyplace
    12,710
    11,848
    Central Virginia
    So did you dutifully wait one more year?
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Measure it at the jump points. A lot of work to measure it at the battery and that really doesn’t matter what
    The voltage is there what matter is what’s getting to the main fuse box then the inverter. Got a few fuses and a long heavy duty cable before it gets there. That’s the true working voltage. At the jump points.
    After 11 years I have never measured the battery voltage at the battery.
    Measure there with the car off then measure again with the car off and turn on the headlights in high beam to check it’s capability to deliver under load. Measure with high beams on car NOT in ready.
    And I’d be way more Concerned about the traction battery’s health than the 12 volt.
    12.7 is pretty good. Unless it dips down to 10.7 under headlight load,
    Prodigyplace likes this.
  12. Docholo
    23
    Yeah, it had to be replaced. I got a new one from the dealer, charged it up on a high quality charger and now the prius runs like a champ.
    I took the old battery and charged it on a desulfating/pulsing charger and discharged it several times. I got an electric load cell battery analyzer that let me discharge into a calibrated 12 watts of load until it discharged to 11.5 volts and stopped.
    In total the old battery could put out 179 watt-hours or, approximately, 14.5 amp hours before hitting 11.5 volts under the (tiny) load. I think that new the battery should be about 45 amp hours when drained at a 27 watt load (?to get discharge 45 amp hours in 20 hours?).
    Anyhow, the old battery is crap. Seems like it has lost about 70% of the capacity relative to the spec when new.
    Thanks all.
  13. edthefox5
    10,096
    4,837
    Clearwater, Florida
    For future readers.
    Other day I measured my 2 year old optima yellow top.
    12.63 resting volt at the front battery jump points.
    12.1 with car off and hi beams on.
    So if you see more than .5 voltage drop at jumps with headlights on hi beam and NOT READY start giving your 12 volt battery the stink eye.
  14. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Acceptable voltage drop changed a lot depending on conditions. If your battery is cold and especially if it’s not charged full (happens easily if you drive short trips in cold temperature) bigger voltage drop is still fine.
  15. Mendel Leisk
    42,253
    If you've got deepish pockets and want in-depth assessment of the 12 volt, pick up a Solar BA5.
  16. greasy
    greasy Junior Member
    Santa Cruz
    I've had great luck using cheap solar panel trickle chargers to extend the life of marginal batteries, and the Prius seemed a perfect candidate for this solution – expensive batteries, lots of current-draining electronics, slow recharge rate. I learned the hard way that leaving a door open (even with no lights), or leaving the key fob in the car can quickly drain an older battery. With a replacement battery costing at least $150, these chargers can easily pay for themselves:
    This being my first post, Priuschat won't let me include links to Amazon. But you can do a search for these products:
    Low output, but very easy to install:
    ALLPOWERS 18V 5W Portable Solar Car Battery Charger
    Higher output, but requires regulator (and maybe an in-line fuse, to be safe):
    ECO-WORTHY 10W Solar Panel
    Y-SOLAR Solar Panel Controller PWM 12V/24V
    EPAuto ATC / ATO 10 Gauge 30 AMP In-Line Fuse Holder
    I hooked one of these directly to the battery, and leave it in the “trunk,” catching sunlight through the windows. This regulator also has usb outlets – handy for charging your phone on a camping trip…
  17. padroo
    2,763
    2,253
    I hope you haven't been holding your breath for a reply but I changed that battery last year, about 15 days out of warranty.
    Sam's Club said it had a dead cell. My electrical service took a hit by lightening and I think that cooked my battery, I lost a 20 Amp circuit breaker at the same time for the charging circuit for my generator. It didn't seem to hurt the generator, I heard it doing it's weakly test run today about 11 months later.
