Avalon Air conditioner
Discussion in 'Toyota Hybrids and EVs' started by Munpot42, Jun 13, 2018.
  1. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Just got back from a trip (Los Angeles to Phoenix and return). Running in the desert with temps from 106 to 110 the AC seemed to be straining to keep the cabin comfortable. With most of the front vents pointing at me I was ok, but if I put my hand toward the windshield, the hand was hot. Normal?
    52,654
    were you in eco mode?
  3. Trollbait
    12,769
    Even with the tinting to cut down infrared energy passing through, the windshield is going to have a green house effect on the dash. Then the air there may not be getting circulated into the rest of cabin air. So a warmer bubble there is to be expected. These are triple digit temperatures for the A/C to contend with.
  4. Munpot42
    1,391
    544
    Nope, regular mode.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    How’s it running today now that you are out of the desert heat?
    Possibly any leaks developed or rocks hit a fin or coil causing a minor weapage?
    How does the sight glass flow look?
  6. Munpot42
    1,391
    544
    Out of the heat it seems fine, now to find the sight glass...
    Raytheeagle likes this.
  7. Mendel Leisk
    42,125
    It should be semi-readily visible, on an aluminum AC line, maybe adjacent to a connection point. If it's similar to Prius, properly charged you should be seeing barely any or no bubbles while the fans and compressor are running. When they shut off, there'll be a little swirl of bubbles maybe.
