Average MPG not showing
Discussion in 'Gen 3 Prius Main Forum' started by lumpy95, Aug 27, 2013.
  1. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I can't find the average mpg display anywhere. On my 2008 I could hit the info button and it would display your average mpg but on my 2013 Prius 3 there is no reading for that, at least I can't find it.
    In the owners manual there is a pic of one of the display's that has it in there, but I can't seem to find that display anywhere.
    Thanks for all reply's and directions.
  2. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Press the trip button on the steering wheel.
  3. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I tried that but avg. mpg doesn't show up on any of the screens.
  4. jnet
    jnet Member
    196
    32
    What average? Life time average or tank average?
  5. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Tank avg. like what was on GEN 2 info screen
  6. jnet
    jnet Member
    196
    32
    I never saw tank average. I just use the trip B. My trip A is the life time average, that's the one I reset after I picked up my car and left it running since.
  7. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Or press Disp until you see CONS on the MID. Maybe on the G2s, it actually said AVG?
  8. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I will have to look through the manual again to see if I can find that pic, possibly I misread it and mistook mph for mpg. I'm old and stuff like that can happen LOL.
    I used the trip button to go through ODO, trip A, trip B but there was no sign of avg. mpg there.
    From the reply's I assume that the Gen 3 screens don't show what the Gen 2 screen showed.
  9. saul
    saul Junior Member
    30
    miami beach
  10. saul
    saul Junior Member
    30
    miami beach
    when you finish your drive and shut off
    a window will appear with the av mpg for that drive
  11. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Hmmm, I don't remember seeing it there either but maybe it was. I will pay more attention the next time I shut it down.
  12. jnet
    jnet Member
    196
    32
    You can't miss it. It's pretty much right in front of you after you turn off your car
  13. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I know the window you mean just didn't see mpg
  14. bisco
    52,750
    for a tank average, you have to reset trip a or b when you fill up. then you can look at it anytime. it says 'cons' short for consumption as phoenixgreg said.
  15. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The disp button shows average for whatever you have the trip meter set for. It's outlined in the manual. If you have it set to ODO or off, the disp button will show your accumulated average since the last time you reset. You should also have an info screen in the nav system where you can access another accumulated average since the last time you did a reset or erase.
  16. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I see a Cons. and a mpg figure when I shut off the car. So you are saying that the mpg figure I see is my avg. mpg from startup to shutdown on that drive?
    I think the Gen 2 screen was more informative/easier to use, since you could see your avg. mpg as you drive. It would tell you from fillup to fillup what you are getting.
    I guess I am a bit confused with the new way of getting statistics on fuel consumption.
  17. phoenixgreg
    1,157
    295
    66
    Phoenix
    Maybe the MID (multi-information display) to the right of the cluster has changed since the 10s, but if you display (disp on steering wheel) the HSI (Hybrid System Indicator), there should be a trip A or B ODO and then a CONS, which is your average mpg along the bottom.
  18. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I have been through those screens and it doesn't show mpg it shows mph. I will look again this morning but that is all I remember seeing. I'll post again this afternoon with what I see.
  19. phoenixgreg
    1,157
    295
    66
    Phoenix
    The AVG mph is to the far right (lower screen) CONS. mpg is in the center area.
  20. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Yes, just to the left of the MPH. You can see some pictures in this thread:
    600 Mile Club | PriusChat
