Avid Ascend, uneven wear - PSI?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kurt Weiske, Nov 12, 2021.
  1. Kurt Weiske
    Kurt Weiske Active Member
    178
    131
    all.
    My Avid Ascends (Not LX or GT) from 2019 are wearing on the inside and outside edges. I rotate them every 10K miles and keep them inflated, usually to 35 PSI.
    The wear pattern seems to indicate underinflation rather than a camber problem.
    They have an 85K mile warranty, I'm looking to have to replace them at 55K. Not unheard of, as mileage warranties are more of a relative comparison than an indicator of how much life you'll get out of them.
    What tire pressure do you run your tires at?
    52,784
    42/40, but it's not necessary. the good thing is, i don't have to check them often, and the higher pressure seems to seal better.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Try 42 front and 40 rear. I've been running Avid Ascends for at least 7 years on the various Gen 2, 3, & 4 Prii I've owned. I get very even wear.
  4. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    I wouldn't be surprised if the wheel (mis)alignment angles causes wear on either edges.
    Being within the green (zone) isn't good enough I suppose.
  5. Peter123
    Peter123 Active Member
    132
    128
    You might have something loose in the front suspension like a control arm bushing or a ball joint.
  6. Kurt Weiske
    178
    131
    I ended up replacing my Ascends at 55K with OK tread in the center but worn on the inner and outer sides. I had a tread separation on the highway 5 years ago when a tire had worn, don't want that experience again.
    I'm back to Defenders, loved them when I had them before.
    Merkey likes this.
  7. Merkey
    Merkey Active Member
    327
    300
    Birmingham, Michigan
    I like the Defenders too. At 58,000 now. I will be happy to get 65-70K.
