Avoiding interfering with radar unit
Discussion in 'Gen 3 Prius Technical Discussion' started by ozboy, Aug 1, 2009.
  1. ozboy
    ozboy New Member
    Australia
    I hang glide & as a result, to carry my 5.2 mtr (>>17ft) long glider, I need 3 supports: the 2 roof racks, plus a support mounted off the front of the car. This support would almost certainly be bolted to under the front bumper (not sure how yet).
    As this would be a metal 'T' pole, it would interfere with the radar unit (radar cruise control). I have heard this unit is behind the front Toyota logo - is this correct?
    If so, I therefore intend to offset this pole to the passenger side - anyone have a suggestion by how much off centre it should be?
    On a related note, this might sound crazy, but has a nudge bar been released for the 2010 Prius? Is this nudge bar airbag & radar unit 'compatible'?
  2. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Yes, it is behind the logo. Sorry I cannot help with your other questions concerning the nudge bar...
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    You may be able to try it, put something metal in front of the antenna and have someone sit in the car, with the car turned on, it may give some kind of alarm or something if it's blocked. If so then you could just move your pole around and see where it can be located. Seems like the beam width of this antenna must be quite narrow to keep from seeing cars in the adjacent lane so you can probably get pretty close.
  4. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    I recommend looking at the tow hook threaded hole in the front bumper as your front support. It's off to one side so wouldn't interfere with the radar. It should be nice and strong as well, as it's designed to pull the vehicle with.
  5. ozboy
    ozboy New Member
    Australia
    I thought this can only be checked while the car is moving??
    The technician at Toyota head office said the radar has a 10 mtr radius (so obviously there is some software to negate it being set off by cars driving alongside - I have to send them a drawing of what I want to do)
  6. tumbleweed
    4,067
    687
    Eastern Oregon
    Knowing the radius won't help, you would need to know the radiation pattern. I don't think they would even know what that was and that information is probably not available outside the design team anyway. I didn't realize it only works with the car moving but that does make sense. Which means you need to come up with a way of trying it. I like David Beale's idea of using the tow hook threaded hole, why not rig up a pole that can be secured to one or both and go out and try it? The owner's manual says you will get a warning message and the cruise control indicator will flash if the antenna is blocked (pg 513). I would bet that it will work fine if you can mount the pole(s) to the tow hook holes, they look plenty far enough off center and shouldn't interfere. Maybe a pole bolted to each one with a cross piece on top?
  7. Tideland Prius
    16,206
    It will say "Clean Radar" if the radar is covered in dirt so I don't know if a metal pole in close proximity would sound off the same warning
