AVS in channel window shade issues
Discussion in 'Prime Accessories and Modifications' started by Mizman, Jan 2, 2022.
  1. Mizman
    Mizman New Member
    N Babylon, NY
    2021 Prius PHV
    Has anyone installed the avs in channel vent shades? They seemed to line up well, I left the windows up for over 24 hours as per instructions. When I finally tested them, all the windows hit the shades and automatically went down. When I tried the drivers window again, it actually cracked the vent shade. I ended up taking them off. Any ideas on how to avoid this issue. Has anyone tried a different brand or tape mounted ones? Thanks.
  2. Darien Day
    Darien Day Member
    126
    35
    SW USA
    2022 Prius Prime
    I've always had issues with in-channel vent visors in my cars. In my last car I switched over to one that uses double-sided 3M weatherproof tape + clips. Much better. Toyota Canada does make one you can get here in the US. Wellvisors also makes one for the PP.
  3. montrealmountain
    montrealmountain New Member
    lorraine, qc
    2020 Prius Prime
    Technology
    I had a similar problem with my 2020 PP and the avs shades. In the instructions, which i know a lot of us do not necessarily read carefully enough, it shows how to install the front shades and how the part near the rear of the window had to be fit. For 5 days i wondered what was wrong and what was the snapping sound i heard when they closed. Re-read instructions and found they were not properly in the slot. it felt like i was going to snap them when i did it correctly. All working perfectly now.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I have the weather tech brand on the front windows of our 2019 Prime;).
    They have worked well;).
    I had the double sided tape vent shades on our old 2010 and they were fine. Just be careful going through car washes with the drying fans at the end:whistle:.
    Good luck and keep us posted (y).
