AWD vs FWD
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Oct 14, 2025.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    I have my opinions as someone who's lived all his life in the steep, icy mountains of Colorado. And so have my parents, grandparents and great-grandparents, going back to times before automobiles even existed. And none of us see much value in AWD, as none of currently own, nor owned before, a 4WD or AWD vehicle. Even the snow plow I drive for the County is a single axel RWD commercial truck, and we only have one AWD truck in the whole fleet. If snow plows aren't AWD, I don't know what actually needs AWD other than off-roaders or people who refuse to plow their driveways.
    It's not that AWD can't help. But it's not a necessity. And generally, it's an expense. I am looking for an AWD vehicle, as mentioned in another post. However, it's for a friend who says they won't drive anything else. But, at the same time, they want a cheap vehicle. And frankly, I'm having a difficult time finding such a vehicle. Although, I digress, as AWD vehicles are cheaper than they ever have been.
    I think the thing is this, AWD can maintain greater acceleration, period. It's not about steering. Sure, it can accelerate more while cornering. That, to me, doesn't mean it corners better. It just means it accelerates better.
    Sometimes you do get a bit of difference in cornering though, due to different weight bias. More weight in the front contributes to more understeer. Having motors and such in the rear can even out the weight a bit more, causes less understeer. Nothing that adding a couple of sand bags in the trunk wouldn't also do. But then again, more weight in the rear of a FWD vehicle means less traction.
    I don't know of any vehicle that has a fun mode. To me, cars are boring, expensive tools that get us from point A to point B. Quick acceleration or whipping out the tail around corners just seem immature to me. But that's just me.
  2. Winston Smith
    Winston Smith Active Member
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Issac, you appear to address whether you and your family find AWD desirable generally more than the specific attributes of the Toyota hybrid AWD set up. I don't dispute any of your subjective conclusions, but note the difference in how it allows a car to turn.
    On that you do seem to agree.
    Emphasis added.
    Being able to turn the car at a higher speed and while applying power is a difference in how the car turns.
    Emphasis added.
    This difference in how cars will behave in a turn and under power isn't an indictment of the judgement of you, your parents or any preceding generation. It's just a difference in how the cars handle that is undisputed.
    You might not be the only person with automotive ahedonia; I believe it is common.
    You might find any specific vehicle feature overpriced, moot or of marginal benefit for you, and you can certainly conclude that people who drive in ways you don't are immature, but none of that is a comment on how the car applies power in a turn.
    I would never try to talk you into buying something you wouldn't want.
  3. Isaac Zachary
    2,779
    1,501
    So we agree it accelerates better. But we don't agree that it corners better. However, if we put both together, then we both agree that it can accelerate better while cornering. That is the difference between you and me.
    None of what I said changes how the car applies power in a turn. It just is not the same as maximum cornering. Yes, I totally agree that an AWD will accelerate better, in a corner or not, than a FWD can. I never said it didn't.
    And these kinds of arguments only make it worse.
    Emphasis added.
    No it's not. The car cannot turn a shaper corner; therefore it is not a difference in how the car turns. It's a difference in how the car can accelerate and turn at the same time.
  4. Isaac Zachary
    2,779
    1,501
    On the contrary, I think context is very important here.
    I said that AWD doesn't help brake or turn. You said, it does help turn, but you put in your own context "under acceleration."
    So why under acceleration? In what situation do you need to turn and accelerate? You mentioned having fun. And that is a valid opinion.
    What about if a moose jumps out in front of your car? What if you just want to get from point A to point B, like to and from work or the store or school? What if you take a corner too fast for the conditions? Then how does AWD help? How does cornering and accelerating at the same time in slippery conditions help you under these common circumstances?
  5. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Where you describe the difference in how a car will turn, you appear to admit the difference.
    Emphasis added. Your premise is directly contrary to your stated understanding that the AWD car can accelerate in a turn better.
    Because that's a common state for a car, the other options being deceleration or a constant speed.
    Turning in either direction from a stop, such as from a stop light.
    This can be illustrated through a thought exercise. Two Priuses are travelling through a long sweeping curve on ice. One has FWD and the other AWD. They each travel at the same speed. The AWD is using 24 ft pounds of torque total,16 pounds through the front and 8 pounds through the rear. For this illustration, any additional torque through the front wheels greater than 16 ft pounds will break the front wheels free and induce understeer. The FWD Prius will use 24 ft pounds to keep the same speed through the same sweeping curve only if it channels 24 ft pounds through the front wheels and induces understeer.
    In this illustration, the FWD car turns less well because it presents the choice to travel more slowly or take an arc tighter than the curve.
    That the driver of a FWD car might drove more slowly when he senses the front wheels washing out is a difference of the driver input, not the car. That the driver of one or the other car considers the car only a joyless financial burden will not itself change how the car turns in that sweeping curve.
    You don't appear to dispute any of that difference. Instead your contention appears than an AWD and FWD car will turn the same so long as they aren't under power. That's a valuable observation to anyone who mistakenly believes that an AWD and FWD car will not behave the same when none of the wheels are being driven.
    #65 Winston Smith, Oct 30, 2025
  6. Isaac Zachary
    2,779
    1,501
    You sure to like to try to provoke anger with those you dialog with, don't you.
    No, I do not and will not admit any difference.
    Anyone asking how AWD could help them on ice and snow isn't going to get some sort of turning benefit, because anyone who's emergency turning on snow and ice IS NOT ACCELERATING!
    Now, if you like frolicking along your roads while you slalom from side to side in graceful burst of acceleration while you turn, then good for you.
    BUT I WILL NOT RECOMEND AWD AS A CORNERING HELPER BECAUSE FOR PRACTICAL PURPOSES, IT SIMPLY ISN'T!
    I don't care how good they accelerate and turn at the same time.
    THE WHOLE REASON FOR THIS ARGUMENT IS THAT I SAID YOU CANNOT TRADE SNOW TIRES FOR AWD WHEN IT COMES TO CORNERING AND BRAKING.
    And I will stand behind that statement and will not agree that AWD makes cars turn better. I will only agree to AWD helping cars accelerate and less likely to get stuck, end of story, end of discussion, end of argument. You want to turn corners, you want to avoid an accident, you want to turn even from a stop, GET WINTER RATED TIRES. Don't replace winter tires with AWD under this premise that AWD turns better, because it simply doesn't.
    I REPEAT, AWD DOES NOT HELP CARS TURN BETTER.
    Buy AWD if you want better acceleration. Well, that and perhaps not having to shovel your driveway or get out and shovel snow from under you car as often.
  7. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    No. There isn't a reason to be angry about anything I've written here. I've discussed the drive system differences, and have taken no issue with what you find valuable, your experience, or your reservoir of ancestral experience with two wheel drive or your preferences.
    I've made it through a lot of great lakes winters with two wheel drive cars almost always on all season tires. Experience and foresight will avoid problems that aren't sufficiently addressed by equipment and technology alone. That shouldn't keep us from clearly evaluating what the tech does without burdening the evaluation with our extraneous preferences.
    Yet,
    I do appreciate that you don't dispute the illustration in post #65. You'll see that the illustration is about the car's characteristics, not driver behavior.
    How a person reacts in a perceived emergency isn't an attribute of the car.
  8. Isaac Zachary
    2,779
    1,501
    Because I didn't want to continue the argument, but I would dispute it.
    Let me put it this way:
    You can either test if a vehicle:
    1. Accelerates better in a straight line.
    2. Accelerates better in a corner.
    3. Corners better.
    4. Brakes better while cornering.
    5. OR Brakes better in a straight line.
    These are 5 different scenarios. AWD helps with 1 and 2, but not 3, 4 or 5. Better tires help with all 5.
    It seems we both agree on these points. What we do not agree on is whether to include #2 as part of the answer to "which corners better." To me, how a car accelerates while cornering is not an appropriate answer to the question "which corners better," but to you it is an appropriate part of the answer.
    With your illustration in post #65, who would ask, "if I enter a corner slow enough to accelerate through the corner, which car accelerates better?" To me, that question and your illustration are about acceleration. Yes, AWDs accelerate better in poor traction conditions, including around corners. To me, that's not the same as cornering.
    Why can't the FWD Prius in your illustration go through the corner with only 16 ft-lbs of torque on the front wheels? It might make it out of the corner a bit later, but it still makes it out of the corner. Isn't that the same result as far as cornering goes?
  9. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    A driver coming up on a sweeping curve. A car steering under power in snow and ice isn't an unlikely or rare circumstance.
    Since in the illustration the FWD car is unable to hold the same line through the sweeping curve, a curve that requires each car to turn, they don't "turn the same whether the car is AWD or FWD".
    Because then it isn't a like for like comparison of cars traveling the same speed. Introducing extraneous variables obscures the role played by the pertinent variable.
    No. It can't be the same because the speeds and times are different. If I told you that I can run just like Usain Bolt because I can walk 500 meters and get there eventually, we'd both get the joke that I cannot, in fact, run just like Usain Bolt.
    If I were to provide an illustration that bald summer tires can turn a car just as well as the best new winter tires in ice and snow, and told you I could demonstrate the lack of difference by having the car creep very slowly through a sweeping curve, would you consider that a valid comparison of bald summer tires and the best new winter tires? Or would I have turned it into a comparison of how people rationally react to real differences in the equipment?
  10. Isaac Zachary
    2,779
    1,501
    In your illustration both cars must apply the same amount of force to the wheels. Forcing drivers to apply a predefined amount of power or torque to the wheels through a curve is a rare circumstance. How much a car can apply power or torque to the wheels in or out of a corner is describing its power and acceleration limits, not it's cornering ability.
    Wrong. Both cars can hold the same line through the sweeping curve after entering the curve at the same speed. The only difference is how much one can accelerate or resist deceleration through the curve. Your statement is only true if the drivers are forced to apply a preset amount of power or torque to the wheels while going through the curve.
    Cornering does not rely on acceleration. Therefore, acceleration in a curve is not a definition of cornering ability.
    1. Because you either entered the corner at speed.
    2. Or because you started from a stop or slow speed, and at slow speeds centrifugal forces have a negligeble effect on cornering.
    It's like blasting your radio. Just because one car has a louder radio and you can play that radio louder than in another car while going around a corner does not mean the radio helps the car corner better. Just because an AWD will accelerate better on ice, whether that's in a corner or not, does not mean the AWD helps the car corner better. It means one thing and one thing only, that the car can accelerate better.
    Context is important. If we were talking about racing I'd likely agree that accelerating through a corner is part of the definition of cornering ability. But we're talking about driving on public roads. In that context acceleration while cornering is not part of the definition of cornering ability. It's like inviting someone to watch a sunrise with you, when in reality, sunrises do not exist because the Sun does not move in relation to the Earth. You can be as technical as you want in your definitions, but if you can't acknowledge context and abstract thought processes in the conversation then important points will be lost even though, ironically, the effort is to try to clear up any discrepancy.
    Hence, I will say this again, AWD does not help with braking or cornering. End of discussion.
  11. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Does a circumstance in which a car makes a turn through a curve need to be common to illustrate the difference?
    So, if one car can make a corner at a set speed but the other can't, that doesn't reflect it's ability to make that corner?
    In other words the statement is true as applied to the scenario provided.
    The purpose a driver might have in mind is not a pertinent variable in the performance of the vehicle itself. Instead, you've fastened on a difference on the driver's purpose and goals.
    Emphases added. If a statement is sometimes true, as you've stated above, repeating that it is untrue is a curious contrast.
  12. Isaac Zachary
    2,779
    1,501
    No. But in communication there has to be common ground. You might as well as explain the quantum physics of turning. People asking if AWD helps a Prius corner are NOT asking how well AWD vehicles accelerate in corners. Therefore acceleration in cornering is still irrelevant.
    Nope. Nor does having a set radio volume or set seating position or set mirror adjustment. You are the one adding a set speed rule, as if anyone turning a corner must follow your rules.
    Simple question. It really is simple. It doesn't take much brains to understand the question. If two cars go into a corner at the same speed, can both come out of the corner? That is cornering. I don't care how much one accelerates or the other decelerates or if one takes longer to get through the corner. Can they both corner the same corner? Yes or no. Not, "but what if one has 16 ft-lbs of acceleration and the other 24?" Yes or no.
    If you want to apply scenarios go ahead. Radio must be turned on scenario, so car without radio doesn't corner with radio on. Heated seats must be turned on scenario, so car without heated seats doesn't corner with heated seats on. Etc. etc. etc.
    Nor does adding in your own scenarios.
    Are sunrises and sunsets sometimes true and sometimes false?
    The statement that a race car driver is asking about how a car corners wants to know how it corners while braking, coasting and accelerating conditions doesn't mean that AWD sometimes helps, and sometimes doesn't help people corner on public roads.
    AWD does not help cars corner. You are the one setting the rule that cornering means a car has to be able to speed up more than another car in a corner. That is not what cornering means. That is your definition.
    #72 Isaac Zachary, Oct 31, 2025
  13. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Were you equally convinced of that as well?
    Good. We can dispose of that as a pertinent variable.
    The conditions that isolate the pertinent variable aren't a rule I've imposed. You can raise matters other than how a car corners, but each time you do that you will not be addressing how a car corners.
    It doesn't take "much brains to understand the question", but it may take some to intuit whether it supports your conclusion.
    If one of the cars decelerates to a stop when it enters the corner, can it also be coming out of the corner? That you "don't care" about additional variables not pertinent to vehicle performance is a problem for your analysis that would describe even a stopped car as an example "That is cornering".
    No, a car that stops on entering a corner does not come out of it.
    That misses a difference. An illustration of the difference in how two cars can perform is pertinent to how the two cars can perform, whereas a difference in the purpose of two different drivers is not pertinent to how two cars can perform.
    Making logic your opponent doesn't improve your odds.
    Even if the race car driver is driving a Prius on a public road? Review your sentence above, and consider whether the identity or purpose of a driver or who owns a road or is admitted to it is an attribute of a car.
    Have you convinced yourself yet?
  14. Isaac Zachary
    2,779
    1,501
    A car coming to a stop in a corner has negligeable centrifugal forces on it. Therefore, the only force important here is accelerating traction. There's no difference between being stuck on a hill with a curve in it than being stuck on a hill that is straight. The hill is too steep, that is the problem, not that the car couldn't corner better.
    End of discussion.
    Look. Let's stop trying to beat this dead horse with a stick and respectfully agree to disagree.
    There are lots of things we agree on. We both understand the fundamental rules of physics that govern the movement of cars and we both agree on how these cars will react in specific situations. The only difference is our definition of cornering.
    If cornering and accelerating at the same time is part of your definition of cornering, then I respect that. If someone comes up to you and asks, "Does an AWD corner better than a FWD on ice?" and you only have time to say yes or no with no explanation, and you say, "Yes it indeed does!" then I respect that.
    For me, I don't care about the semantics of whether the car comes out of a corner faster or not. If someone asks me,"Does an AWD corner better than a FWD on ice?" my answer is "No, it doesn't." And if they ask, "But wouldn't an AWD accelerate better through a corner on ice?" I would say, "Well of course an AWD will accelerate better through a corner on ice. But that's because an AWD can accelerate better, not because it corners better."
    That is my answer, and I will continue to preach that AWD cars do not corner or brake better than FWD cars in slippery conditions, they only accelerate better in those conditions, and I'm sorry if that bothers you. If you want to keep trying to convince me and drag out this conversation, go ahead. I've put you on my ignore list and I will not be participating anymore in this conversation.
  15. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Clearly.
    Yet later,
    Then,
    You don't appear to use "end" precisely either.
    Given your prior use of language, you'll pardon me if I don't read that as literal.
    Don't be sorry; this hasn't bothered me. I've discussed the topic, set forth the difference, and answered the questions you posed without evasion or suggestion that you are immature or stupid. If that bothers you enough to announce that I am on your ignore list, you might think about why that is.
  16. Isaac Zachary
    2,779
    1,501
    I've discussed the topic, set forth the difference, and answered the questions you posed without evasion or suggestion that you are immature or stupid.[/QUOTE]
    I still find your definition as an exaggeration, as more of a justification for your purchase decision.
    I don't see any difference that you've supposedly set forth. Cornering is cornering and accelerating is accelerating. Those are two different maneuvers. It doesn't matter if the car can accelerate better in a corner, because acceleration is acceleration, not cornering. Braking, blasting music, or running the windshield wipers in a corner does not help with cornering either.
    I will not trade your definition of accelerating in a corner as "better cornering" for my 37 years of commercial and professional driving in the Colorado mountains nor for the several driving schools and classes that I have attended. Never, in my whole life have I had an instructor say, "but if you get an AWD, you can corner better." Nor will I teach my driving students that either. AWD does not help braking nor cornering. If you want better cornering, get better tires or some sort of traction device like snow socks.
    Yes, AWD can accelerate better in a corner. But saying that because of that an AWD can corner better is twisting the truth for someone's own personal purchase justification. It just simply is not true. I doesn't matter if the corner is 50' long and 90° or 500' long, or whether it's built with a 4% super or if you're in the outer lane on a 4% crown, or whether you have an 8% uphill grade or are on flat ground or are on an 8% downhill grade. The AWD will not help with the cornering part of the situation.
    Then again, I tried to find some sort of text book reference on the subject and all I found was Consumer Report's take on it: Although having power delivered to all four wheels increases straight-line traction, neither system improves braking, and most systems have little to no effect on cornering. And even then, only when accelerating.
    #76 Isaac Zachary, Jan 5, 2026
  17. BiomedO1
    BiomedO1 Senior Member
    4,592
    2,409
    Left Coast
    That's the secret to buying a slightly used car; DO NOT limit your search to the bottom of the line trim level. Someone else has already taken the depreciation hit and most likely couldn't afford it and was talked into the higher trim for "just a few dollars more a month".:ROFLMAO::LOL::D:whistle:
    All the banter above would be highly dependent on how the all-wheel drive system was implemented and how tight the traction computers are programmed. IMHO; the Toyota Prius system is pretty loosey- goosey, when compared to a Subaru AWD system. Totally different hardware and software implementations and really comparing apples to oranges. Again, IMHO.........
    #77 BiomedO1, Jan 5, 2026
    Templeton and otatrant like this.
  18. RobotBastard
    RobotBastard Junior Member
    30
    Connecticut
    2024 Prius
    It's always enjoyable seeing a crazy person who hates cars and hates driving come into a forum and insist that they aren't leaving until they get the last word in every thread.
    Isaac Zachary likes this.
  19. Isaac Zachary
    2,779
    1,501
    I apologize for taking out my frustration on this forum and its members. I guess the topic of driving around as fast as posible on ice really pulls my nerves.
    I used to enjoy driving quite a bit. Maybe I will again some day. But when you've lost 12 different people in 11 different car accidents, you don't exactly think of driving as "weee, fun!!!" anymore.
    #79 Isaac Zachary, Jan 18, 2026
  20. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    No problem, and a Happy New Year to all.
