Awd when?
Discussion in 'Gen 5 Prius Main Forum' started by phase, Nov 17, 2023.
  1. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    So today I took an awd 2024 Prius for a test drive. Felt weird to drive versus my Ioniq but felt great. Was getting 58mpg with city driving and heat on. Much higher than the epa rating. I was surprised to see those numbers on the awd.
    my question is, when does awd engage?
    I saw the screen for the “ awd” section and it shows which wheels are being engaged. Even accelerating at low speeds, I only saw the front wheels on the screen light up. Never saw all 4 wheels being used
    I was under the impression that awd is always being used at speeds under 43 mph
  2. Trollbait
    12,832
    Read the SUV hybrids will use it on launch from a stop. That may only last to 5mph or so under normal conditions. They may have a mode where it can be engaged at low speeds for 'off road' use.
    Otherwise, it only comes on when the front wheels start slipping.
  3. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    I've noticed on the drivetrain display that it activates in relatively slow turns onto an intersection from a stop for just one side.
  4. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    How do you activate it always for slower speeds? I just want to use it for off road and deep snow. Nice how it still uses front wheels for better fuel economy in dry conditions. I guess the epa ratings are from driving more aggressively and that’s why the awd is engaging more and lowering the numbers
  5. Trollbait
    12,832
    Turning it on for low speed may not be an option. Only heard of that with Toyota SUVs, and not all of them. If needed for snow or dirt roads, it should just come on whenever it is needed.
    The EPA tests are very laid back; acceleration rates well over 10 secs to 60mph. The rear motor adds weight, and unless it is an induction motor, it applies a braking force when it isn't powered. Even with an induction motor, there is likely more friction in the rear axle compared to the FWD model. That's why the rating is lower.
    reallyreal and Mendel Leisk like this.
  6. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    The AWD is computer generated, meaning it's always on but engages wheels differently as it senses tire slippage.
    I use the B gear also in snow.
  7. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    how do you change or use that gear?
  8. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
  9. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    its only a little over 100 pounds heavier, which isnt that big of a deal. would only affect city driving but very very slightly. highway isnt affected by weight. the friction could make sense, but affecting several mpg doesnt seem like the reason why?
    i guess the best way to even out the awd hit would be to just switch to 16 inch wheels that are also lighter weight
  10. Blackat
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    If you look at the shifter, you’ll see two down arrows. To the right is the B gear to the left is the D gear.
  11. Trollbait
    12,832
    The two core EPA test cycles where developed from drive patterns in the 1950s and '60s. The highway one is not at a steady speed, and has numerous slow downs and re-accelerations.
    https://fueleconomy.gov/feg/fe_test_schedules.shtml
    That said, what I called magnetic braking could be the main culprit. Proper name is https://en.wikipedia.org/wiki/Eddy_current_brake. Many casting fishing reels make use of the principle to control line out speed.
    Most AWD EVs do not power both motors at the same time; inefficient to do so. When unpowered, the permanent magnets in the secondary motor apply a braking force to that axle. It's like having the friction brakes drag. More powerful the motor, the more braking, which is why the new AWD Prius sees a bigger penalty than the old one.
    This can be avoided by using an induction motor which doesn't have permanent magnets(Teslas), or a clutch on the motor(upcoming Ram PHEV). The first is less efficient when powered, and the later adds complexity to the system, but overall can be worth doing. Haven't seen anything to suggest Toyota uses either.
    Something to consider in any car if best efficiency is the goal. The improvement in a Prius might make it hard to justify the cost though.
  12. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    The awd prius for this gen had a huge improvement bump versus last gen. Now it’s only a 2 mpg overall hit where last gen it was 4-5.
  13. Blackat
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    My 16's are at least half the weight of the OEM
  14. Trollbait
    12,832
    It's the same 3mpg penalty to combined for each. The gen5 is hurt more in the city rating. The gen4 AWD is 170 pounds heavier. There is likely the difference in it having NiMH instead of Li-ion in effect.
    I must have been thinking of Toyota hybrid SUVs. When FWD models were available, the mpg difference was smaller.
  15. Mendel Leisk
    42,378
    Snow time is the one time I'd be inclined to use ECO mode (if it still exists on gen 5), for it's more sluggish response. And leave the "gear" in D.
  16. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    984
    Monument, Colorado USA
    Good answers! This will be my 3rd winter in my 21 AWD Prius and I'm much more confident to drive it in the snow and ice. The computer traction system controls when the rear wheels' motor engage automatically...I notice mine only engaging when driving up snow or icy hills and the front are slipping.
    I asked my mechanic that, since it's an AWD, do I still need to rotate the tires every 5,000 miles and he said yes because the front tires, still, take most of the wear and tear even on an AWD car.
    For deeper snow, however, I will take the 4x4 Tundra over the Prius.....a lot of snow can get underneath and high end the car making you get stuck...even with AWD. We have many here in Colorado with AWD Subaru's who learn this lesson (I have a tow rope in my Tundra to pull people out when they get stuck....lots of Subaru's and Honda's have been helped!)
  17. ColoradoBoo
    1,356
    984
  18. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    Have you noticed a diff in drive quality or mpg?
  19. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    When I get my awd prius I’ll be installing an air suspension so I can push a button and lift it in deep snow an extra few inches, and then lower it on dry highways
  20. Blackat
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    That's not going to do what you think.
