B mode: What is the advantage to use B mode when driving, more regeneration? more economy?
Discussion in 'Prime Technical Discussion' started by Gaƫtan Lafrance, Jul 5, 2018.
  1. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    Yeah I have to admit being a bit of a control freak when it comes to maximizing miles per tank of gas (about 950+ miles per tank on the average).
    I manually move between EV and HV and never use EV-Auto. My daily drive is about 18.5 miles one way and I'm able to get about 100 MPG by charging about 3 times per week.
    I try to use EV only at lower speeds (below 40 MPH preferred) and switch to HV when I know I'll be going 50+ for at least 5-10 miles. Remember, electric motors drop have a severe dropoff in efficiency above about 25-30 MPH or so.
    PS - yes this thread can probably go on to at least 50 posts or more.
  2. fuzzy1
    10,458
    I'm inclined to believe that 'brain-dead' and 'just their DRLs' are two sides of the same coin.
  3. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Most newer cars now have lighted display in the daytime. So in the dark they will think their lights are on since the DRL are bright and their gauge is lighted.
  4. Tideland Prius
    16,559
    Annoying as heck. People can't even take the time to read the owner's manual or the salesman couldn't be bothered to show them all the new features and ensure that their customer leaves the dealership understanding the vehicle. For my cars, the salesman (sorry product specialist) did go through the basics.
    Canada is introducing a law to counter that but it won't be in effect until 2023. (or at least, manufacturers have until 2023 to figure out which 1 of 3 options they want to implement).
  5. Gaƫtan Lafrance
    101
    77
    MontrƩal, QuƩbec
    Technology
    Thanks so lot for this precision
    Merci beaucoup pour cette prƩcision.
  6. akbetts
    akbetts Junior Member
    Vermont
  7. akbetts
    Vermont
    The main advantage I have found of the B mode in Vermont is going downhill on steep snow covered roads in winter. In the B mode you dont need the foot on the brake, and the computer controlled braking and traction control keeps the car at a safe low speed in a straight line.
    jerrymildred likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    That's pretty much what it's for. (y)
    Using it on flat ground to supposedly increase regeneration is silly. You can get the same regen with the brake pedal, which you'll need to use anyway if you plan to stop.
    Starship16 likes this.
  9. padroo
    padroo Senior Member
    2,763
    2,252
    I use it in stop and go traffic so I don't have to keep tapping my brakes. Kind of like driving a stick shift, it will slow down and not coast.
    Starship16 and Old Bear like this.
  10. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    That's been my experience in stop-and-go city driving. One still has to use the brake pedal to come to a complete stop, but otherwise "B" mode allows a very comfortable driving experience when constantly going from 2 mph to 20 mph and back.
    Interestingly, I recall learning that back in the days of manual transmission cars, city taxi drivers would just leave their gear box in "second" and not bother shifting when in heavy traffic. It probably was no worse on their clutch than going between "first" and "second." I'm sure their clutches did not last very long in that kind of service under any circumstances.
  11. stevepea
    stevepea Senior Member
    535
    581
    I just drove 28 miles roundtrip city driving yesterday and got 6.8kw/hr using B. Roundtrip (about 14miles each way). Level driving along city streets on a Saturday, all in B, as is my default for city or start-and-stop driving. Looking back at my readings for days where I don't use freeway it's usually in the high 5s (5.4-5.8 typically, using B), though it sometimes goes to the mid 6s, or occasionally down to 5.0, but if it's just street driving in EV "B", mid to high "5s" is the norm. I was going to snap a picture of the readout but didn't bother...
  12. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    I'll throw in my impressions so far. I previously had a 2016 Prius Two and traded it in for the Prime Plus. One thing for sure is that the regenerative braking is much more robust than on the 2016...I haven't plugged my scanner in to see just how much current is going back into the battery but I can say that going down several miles of 6-9% grades can regenerate somewhere around 3 kWh of charge and I never had to use B yet in the Prime. The regeneration is stout enough to keep the speed under control without using the brakes. Unless you're going down a very steep grade you probably won't need B at all.
  13. jerrymildred
    11,517
    14,152
    Tampa, FL
    Same thing but on a smaller scale with my PiP. I finally got to drive it in the mountains last month and was IMPRESSED!
  14. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Another advantage of using "B" is save your brake pads.
  15. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Thanks. I will have to try that sometime.
  16. jerrymildred
    11,517
    14,152
    Tampa, FL
    Where did you get that notion? Using B mode does nothing to save brake pads. Brake pads come into play when you call for more braking force than can be applied with regeneration. Whether you're in D or B makes no difference. Please read the manual.
    Starship16 and axle2152 like this.
  17. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Oh I thought its like an engine brake. :D
    Thanks for clarifying it.
  18. jerrymildred
    11,517
    14,152
    Tampa, FL
    Remember that when you regenerate, not all of that deceleration energy goes back to the battery. Some of it is lost in heat in the wires and MGs. The higher the regen, the higher the current. The higher the current, the higher the heat loss. If traffic allows, it's more efficient to decelerate more gradually by allowing more following distance.
    rbdigital, Starship16 and axle2152 like this.
  19. jerrymildred
    11,517
    14,152
    Tampa, FL
    B mode works differently in HV mode vs EV mode, I discovered. Also the plug in cars act a little differently than the others. So a full explanation gets pretty lengthy. There may already be one here on the forum, but I don't have time to look for it now. If there isn't one, we should probably generate one because this is a confusing topic and understandably so.
    Starship16 and utsug like this.
  20. jerrymildred
    11,517
    14,152
    Tampa, FL
    I forgot to say that yes, it often is an engine brake, but not always. ;)
