"B" on transmission.
Discussion in 'Gen 2 Prius Main Forum' started by brockketcher, May 19, 2005.
  1. brockketcher
    brockketcher New Member
    Saint Cloud, MN
    I just picked up my prius...put 350 miles on it in the first two days...love it. Can someone tell me when and where they use the "b" on the transmission to thier benifit???? I don't get it. I asked the sales person and he said to use in in town...but I read the manual and it said not to use it for long periods of time. whats the deal???? thanks
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    It's not B for battery it's B for brake.
    Someone will correct me if I'm wrong....but I believe you use it when you have a lot of downhill driving. It's an engine assisted brake...the equivalent of low gear on a conventional car.
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    if you do a search on B here on PC you'll find at least 2000 lines on it.
  4. xevious
    xevious New Member
    187
    Oregon
    1) Use the search feature.
    2) Please post in the appropriate forum. This is not newsworthy.
    Enjoy your Prius!
  5. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    17
    Page 138 of the Owner’s Manual kind of covers what “B†is for, but they could have done a better job of explaining the function is like low gear in less advanced cars.
    Toyota so should have labeled it “L†for low gear, or “EB†for engine braking. “B†is not intuitive.
    [You are right xevious . . . this thread is not “News.†I clicked on the blue square to notify the moderators . . . but more out of curiosity in seeing what the blue squared does.
    I guess we shall see. :wink: ]
  6. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    The blue box just emails us mods, to let us know that a member has reported an improper post.
    We can then decide the appropriate course of action, if any. In this case, the thread has been moved to the general forum.
  7. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    B=Brake. Works for me. L=Low wouldn't be completely accurate. Unlike a true Low, B does not affect acceleration, only braking.
  8. Mystery Squid
    Mystery Squid Junior Member
    IMO, I avoid engine braking, I have yet to be convinced periods of engine load at the expense of brake pads/rotors wear is truly "worth it". Can't speak for the Prius yet, but higher end pads and rotors for any car I've ever owned just aren't that expensive, and they're easy to replace by the home mechanic....
  9. Jaguar88
    Jaguar88 Member
    172
    La Crescenta, CA
    I don't know if engine braking is good or bad. I thought it was a continuous regenerative braking mode. I use it everyday on my way to work.
  10. Mystery Squid
    "good or bad"... That's sort of like saying which is better MAC or Windows... lol There are TONS of arguments about that.
    On another note, unless I'm mistaken, I don't THINK engine braking increases regeneration by any margin. I could be wrong, let's see what Danman chimes in with... :mrgreen:
  11. jeromep
    jeromep Member
    827
    Eastern Washington State
    B is an automatic low gear simulator, through the use of engine compression braking, a reliable and well developed technology that is many, many years old. In fact, so many things are simulated on the Prius that we don't really notice it. Break pedal feedback is essential simulated. Braking feels like friction braking, however it is mostly regenerative except for very low speeds or panic braking situations. I have read it here described as a "wet" brake by wire system since hydraulics are involved at many different stages in the system. Steering is still physically connected to the rack, however the electric assist system simulates much of the same behavior as a hydraulic system. Throttle is also by wire. This has been offered for many years now on vehicles from many different manufacturers. Pedal resistance is provided by springs rather than the drag of a cable going to a throttle body.
    Engine braking is not bad for the engine. The engine reverts to its more primitive form, a compressor. It is fully oiled and cooled when in B mode and therefor there is no more wear and tear than if the engine were running.
    I'm sure that Danman has more detail to add.
  12. coloradospringsprius
    171
    I used "B" mode for the first time a couple of weeks ago, coming down Cameron Pass in Colorado. It was great - I'd never used the brakes so little on a long mountain descent. I've never seen any need for it on regular hill. The standard light regen touch on the brakes works fine.
  13. Mystery Squid
    Well see, there I sort of disagree (at least, in terms of usage. I've even read opinions that say engine braking should be encouraged). The engine is being used, as opposed to not being used. Therefore, on the most basic level, it is, at the very least, being used when "engine braking". :mrgreen: Whereas by using brakes, you are not using the engine, simply wearing brake pads and rotors. Given, what would you rather place wear upon?
    IMO, the only vehicles that legitimately have the need for engine braking, are large, heavy vehicles, various sports cars, of if your brakes should completely fail for whatever reason. The pads and rotors on the Prius are ample for its weight, and will likely last a long, long, time....
  14. brandon
    brandon Member
    771
    Manhattan, KS
    A coworker of mine has a long, narrow, steep, and winding gravel trail (without a shoulder) that leads up to his home from the highway. You don't want to go faster than about 8 mph or you'll lose control and total your Prius. I use "B" on the descent after visiting him. I feel I have better control over the vehicle than with the standard brake setup.
  15. jeepien
    jeepien Member
    165
    New Jersey
    But it is not true that by stepping on the brake pedal you are necessarily "using brakes". You are probably just using regen braking, and therefore wearing out neither the brake pads nor the engine.
  16. Frank Hudon
    4,147
    MG2 in generator mode sends it's output to MG1 which uses the ICE as a load to buck against to absorb the current that would normally go to recharge the battery. When you have all green bars (80% charge) the battery will not accept anymore charge and if the hill your on is long enought you'll note that in D mode your using the friction brakes to keep the cars speed in check. If you then put it in B mode the output from MG2 goes to power MG1 to slow the car by using the ICE as a load.
