B versus D
Discussion in 'Gen 3 Prius Main Forum' started by LDB, Oct 9, 2016.
  1. Mendel Leisk
    42,368
    My take: in normal use the brake pads are not used much. You apply the "brakes", and it's mostly regen that's happening. The only time the brake pads are used seriously is on extremely long descents, long enough that the hybrid battery is charged to the point that the car refuses to charge it further, switches to full time brake pad use, and you still have a goodly stretch of downill in front of you.
    This does not happen in day to day driving for most people. I would reserve for coming down Mount Seymour, or Mount Baker, or similar.
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    True, but the OP started out with "when I let off the accelerator" and "does it do anything differently than if you were to apply brake pressure while in D?"
  3. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Yes, I wasn't aware of just how it operated so in my application B is not at all useful. I will keep it in reserve in case I ever make a long trip including mountains and will stick with the brake pedal here to increase the amount of regen.
  4. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    As far as why B would run the engine more when not engine braking, I suspect catalytic converter temperature is the concern. Spinning the engine dry will blow cold air through the catalytic converter, which will then make it less effective when the ICE needs to run for propulsion.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't know why there seems to be a subconscious desire among some people to complicate when/how to use "B".
    D is "Normal Driving"...that's going to cover it for 99.9% about 99% of the time.
    B is recommended for down hill/steep descents.
    I never used "B" to "downshift"...The Prius is not a manual transmission.
    I never used "B" in any normal driving conditions.
    I used "B" as presented in the Toyota Prius Owners Manual. Nothing more, nothing less.
    #25 The Electric Me, Oct 14, 2016
    Coast Cruiser and Mendel Leisk like this.
  6. Mendel Leisk
    42,368
    Same impulse kicks in when they're told not to tow, or for sure to use Toyota ATF WS.
  7. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I have yet to use B. Most steep descents I take are on the highway. Can coast for the most part. If needed, slightly modulate the brakes for Regen.
  8. fuzzy1
    10,722
    If you are mostly coasting, it isn't steep.
    exstudent likes this.
  9. solrunner
    solrunner Member
    114
    37
    Reston, VA
    Like it says in the manual, B mode means engine braking. It's mainly designed for going down long hills. I used it yesterday coming back from the Shenandoah mountains. It is a little odd to hear the engine groan, but it's better than burning up your brake pads. Also the brakes will be less effective when they're real hot, right after you take a long hill holding the brakes.
    I've also read one or two people recommend B mode for driving in the snow. I haven't tried that too much.
    Coast Cruiser likes this.
  10. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    I would not recommend B mode for driving in the snow. In situations on snow or ice when your foot is off the accelerator pedal, B mode will slightly reduce steering responsiveness.
