B1503 DTC
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by autoz, Apr 29, 2018.
  1. autoz
    autoz Junior Member
    22
    Trindad
    2013 Aqua
    Yesterday the red temperature warning light came. Car was parked in the garage all day. Only after I turned on and car idle for 1 minute light came on.
    Techstream showed DTC 1503 exhaust heat management warning detected.
    Tried clearing but DTC still showed up.
    I did remove the AC amplifier before this ( unjacked and reinserted ) because I was testing the amplifier on a next car.
    Any help on solving much appreciated.
  2. autoz
    autoz Junior Member
    22
    Trindad
    2013 Aqua
    Car is a Prius c 2013
  3. autoz
    autoz Junior Member
    22
    Trindad
    2013 Aqua
    Just an update the temp light is going off when I turn the car off. After I put the car on or in ready the light takes approximately 1 minute before it comes back on.
    I gave the car a little run and the temp Went up to 60 deg.C not seeing any sign of overheating.
    Put the ac in cold/hot setting and it's working fine.
    Any thoughts anyone.
  4. autoz
    autoz Junior Member
    22
    Trindad
    2013 Aqua
    I resolved the issue. I disconnected the 12V battery negative for a few minutes, pump the brakes a few times waited about 10 minutes after, reconnected the battery and presto of t worked no more temperature light. Cleared the code from the history car is working wonderful.
    RicRic and SFO like this.
