B1504 Lost Communication with Steering SW
Discussion in 'Newbie Forum' started by xamza, Jul 19, 2019.
Tags:
  1. xamza
    xamza New Member
    16
    lahore
    Problem: Prius III - Trip / Disp buttons on the steering wheel are not working. All other buttons work fine. Is there a way to change from ODO to Trip A/B via OBD ? Techsteam reports error "B1504 Lost Communication with Steering SW". what i can do? i try changing the spiral cable, button but no things works.
    49,507
    did you use a new oem cable?
    xamza likes this.
  3. xamza
    xamza New Member
    16
    lahore
    I do not know about this cable could you please show me picture of that. I try changing spiral cable, control buttons even also change the whole meter but trip/disp buttons not works.
    49,507
    sorry, i meant the spiral cable. was it toyota or aftermarket. many aftermarket cables have been defective out of the box
  5. xamza
    xamza New Member
    16
    lahore
    Its of toyota genuine one.
  6. bisco
    49,507
    i don't know what else it can be, if it was installed properly.
    if anything could change trip meter, it would be tech stream
  7. xamza
    xamza New Member
    16
    lahore
    I checked the wires coming from the meter and going inside the spiral cable there are 1 wire with no pulse. is there any issue in that wire ? possible?
  8. bisco
    49,507
    anything is possible. i would suggest a subscription to the service manual at techinfo.toyota.com
  9. AzusaPrius
    AzusaPrius Senior Member
    1,878
    823
    The problem is your spiral cable/clockspring. You can find them cheap on ebay. I found mine for $10 and now all my buttons work and no more airbag light.
  10. AzusaPrius
    1,878
    823
    This is the spiral cable, I got it from ebay and it fixed all issues. You will have to get a free tool rental called a steering wheel puller from autozone. tapatalk_1591635437625.jpeg
