B2784 Entry and start/smart key
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Darcy851, Jun 12, 2026.
  1. Darcy851
    Darcy851 Junior Member
    United States
    When taking my Prius in for a smog the other day, I got a B2784 code on the OBD scanner. I replaced the start button, but this hasn't gotten rid of the code. I checked all the wires plugged into the Immobilizer ECU (blue box behind the glove box) but they all seem fine. I checked 12v battery and it's in good shape. Disconnected and reconnected the 12v battery and cleared codes on the OBD scanner and the B2784 code is still coming back. Anyone else had experience with this issue? I would appreciate any suggestions for what to try next.
    One other question: does your Prius give one single beep every time you turn it on? When I hit the power button it beeps once when going into ready mode. I'm second guessing myself on whether it had always done this or if it correlates with the B2784 code appearing.
  2. Darcy851
    United States
    Solved: I think maybe there was a lag in the effect of replacing the start button. I had the code re-appear after I cleared the codes one time after replacing the start button. However, after that, I cleared the code again and it didn't come back. So could be from replacing the start button or could be something else. But no more code now!
    bisco and frodoz737 like this.
    52,891
    congrats!
