Back to the drawing board.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Jul 13, 2022.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    I'm really curious how in the heck he is charging at a 2A rate, because once the batteries hit about 8.6V, they start to slightly swell at any rates above 0.5A.
    My charger cannot cutoff at a certain voltage, misses the delta peak, etc. There's no way I could feed my modules 2A without them turning into balloons, or unless I literally sat and looked at them until gaps appeared between the modules, indicating swelling, but that would be like watching paint dry.
  2. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Not sure what to say, consider that we had no way of commenting on your discharge capacity when the problem was the charger leads. Now to say anything about your swelling again have no idea how you are clamping the modules. If they are clamped properly, why would they swell? The Prius BMS is charging at 60A intermittently.
  3. Prius92
    595
    122
    Iowa
    The modules are bolted and clamped in the factory setup.
    When I mean swelling, you can visibly see gaps between the modules that increase in distance to about the width of a credit card when they do swell.
    You can see what I'm talking about in the first post on this thread.
  4. alftoy
    1,132
    519
    Why are you charging modules side by side? Also can't state what the torque settings are for the clamp rods. Really tight someone had posted. Clamp rods are installed top and bottom?
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    I had set the battery pack onto the battery "shell" bottom sheet metal housing. I then stuck the prius battery exhaust duct into the air slot on the bottom. The other end of the duct is taped to a small plug-in box fan (set to low speed).
    I stuffed some foam into the bottom slot at the far end of the pack- so air from the fan continuously flows into the bottom of the pack and up through the modules.
    This let me charge to 7500mAh at 1.5A with no bulging or swelling. (I also charged modules at the same time that were not close together).
  6. Prius92
    595
    122
    Iowa
    Did your charger automatically end? I had the blower from the Prius itself blowing on the modules and they still slightly swelled.
    Since the heat source is internal, I can't imagine being able to cool the modules down enough to prevent swelling, unless you had them inside a walk in freezer or something.
  7. Prius92
    595
    122
    Iowa
    I had made that error initially but have stopped charging the modules together. But honestly I don't see how it makes much of a difference when grid chargers charge them all at once.
    I used some left over electrical stuff I had and made some ends for the discharger which can now be bolted on, no more messing with alligator clips. The issue with the discharger is that if it detects a voltage below 5.4V AT ALL, it shuts down and has to be restarted, so even slightly bumping the clips once installed will trigger that.
    As you can see below, I can now bolt the connectors on, and am using one of the copper bus strips for the other side of the modules.
    Before you ask, NO the large 200A blade fuse is not part of this lol it's for something on eBay I'm selling.
  8. Prius92
    595
    122
    Iowa
    Found a way to kind of speed things up, as long as I'm not busy and can babysit.
    I notice modules start to slightly swell above 8.75 volts when current applied is over .6A.
    So what I've been doing is charging the modules at 5A with my voltmeter attached, and once the voltmeter shows 8.7V, restarting the charger at .6A.
    It would be nice if they made a programmable multi stage charger, where this could be done automatically, but that would probably not be cheap.
    Also something strange I noticed, when I let two modules set overnight with .5A charge applied, one of them measured 9.9V with my voltmeter. Never seen one get so high, but no swelling, and discharged over 4,000MAh, so all is well.
    Above the high cutoff voltage of the modules, excess current from the charger is dissipated as heat, as others have said.
    There is probably a "magic number" of amps that starts to cause swelling, which is at least 1.5A, but at .6A, you can leave the charger on for 10+ hours without swelling.
    I am still not sure technically speaking..what voltage of the module is considered charged..as the charger does not shut off due to missing the delta peak. 6V is technically considered the bottom cutoff voltage. I believe this number is 8.7, but as I've read..if you continue to charge for several hours over this, it will perform what is called a "form charge" which is crucial to the refresh process besides discharging to around 3V per module.
  9. Prius92
    595
    122
    Iowa
    Welp, back to the drawing board yet again. I accidentally reversed polarity on the discharger, and instead of blowing the fuse on it like it was supposed to in case of a RP situation, it blew out a surface mounted IC chip. So now I'm going to have to order another one. ..
  10. Prius92
    595
    122
    Iowa
    Alftoy, I tried to PM you, but it won't let me.
  11. alftoy
    1,132
    519
    #71 alftoy, Jul 26, 2022
