Back-up beeping
Discussion in 'Gen 4 Prius Technical Discussion' started by nednvermont, May 8, 2018.
  1. nednvermont
    nednvermont Member
    67
    74
    Vermont
    I recently had my 2017.5 Two into the shop for 5,000 mile check. I asked the technician to please turn off the back-up beep, and that I'd heard this was possible through this website. Tech said he couldn't turn it off, but that he could make it so it just beeped once. I said "Good enough. Do it." Tech comes back a few minutes later and says that he was wrong and that he could only make it made one constant beep when in reverse. "Don't do it!" This "feature" is my only real gripe with the car, and am asking how others have addressed it. Thanks!
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    The tech was wrong.
    There are two options (and this is also explicitly stated towards the end of the manual). 1) A repetitive beeping while R is engaged. 2) A single short beep as soon as it's engaged. It also says in the manual that you can take it to any authorised Toyota dealer to get that option, and any others, changed. In my manual it's section 8-2 titled "Customisable Features":
    "Reverse warning buzzer. Signal (buzzer) when the shift is in R. Default setting = Intermittent. Customised setting = Single beep."
    I used the Carista app and an ODB bluetooth adaptor to do this myself only yesterday. Took 2 minutes. It definitely only beeps once for maybe 1/4 of a second when putting it in reverse now.
    Sommer86, Gas Mizer, Tyfly and 2 others like this.
  3. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    Hah! Got another one. The tech probably succeeded in disabling the beep. But then he put the car in reverse to test it. Beeeeep! Door was open. You're not supposed to drive with the door open. Close the door and see where he left the beep setting.
    RCO and nednvermont like this.
  4. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    I had mine set to a single beep at PDI so it can be done!
  5. bisco
    49,375
    so sad how ignorant toyota mechanics are.
    Tyfly likes this.
  6. nednvermont
    nednvermont Member
    67
    74
    Vermont
    Thank you! Will keep you all posted.
    RCO and Harters like this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    It was a condition of me buying my car that they turned off the constant reverse beeping. I think it still beeps once. They can do it.
    RCO and Tyfly like this.
  8. Tyfly
    Tyfly Member
    65
    94
    I had the same adjustment made after the purchase of my 2017 Prius last year. Only one beep now. It’s so much better!
    My salesman and the service advisor were going to charge me to change anything! They eventually agreed to do it for free. Lesson learned, get it all in writing before you sign.
  9. Fester
    Fester Active Member
    201
    198
    Ohio
    There is also a code if you use a ScanGauge to toggle the beep. Speaking of the ScanGauge and the Gen 4's, the company (linear logic) had sent me a small data logger to retrieve more X-Gauge codes, but the ones they sent me after running the logger did not work. They emailed me 2-3 weeks ago saying that they were working on a new data logger which they would send to me to run when they finished work on it.
  10. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I know (and used) the code on the Scangauge to set my Gen 3 to a single reverse beep, but thought there wasn't a code for the Gen 4 or Prime. If there is could you post it (or a pointer to it)? Much thanks if so - that's been driving us crazy for a while now, and it's still a few months to when we'll need the oil changed which was when I was going to ask the dealership to do it.
  11. Fester
    201
    198
    Ohio
    Actually the Gen 2 codes worked for me in the 2017 gen 4.Got the Prius under a car cover today, but if these don't work, I'll check the one in the ScanGauge because it does work. Here they are...
    TXD: 07c03bac40 (change the last 40 to 00 if you want to re-enable it.)
    RXF: 047b15ac0000
    RXD: 2008
    MTH: 000100010000
    Still waiting for LInear-Logic to send a new data logger to get some new gen 4 codes...
    mountaineer and walterm like this.
  12. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    I used the Carista OBDII connector and iPhone app to change it on my Gen 4. There are also a host of other options that can be changed, as well as using it to pull any diagnostic codes that may pop up. Well worth it...
    kithmo likes this.
  13. The Professor
    598
    809
    UK
    Excel
    kithmo likes this.
  14. walterm
    466
    202
    34
    2022 Prius Prime
    Worked like a charm! Our Prime no longer sounds like a forklift in reverse! :)
    nednvermont likes this.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    krmcg likes this.
  16. Drhyed
    Drhyed Junior Member
    2018 Prius
    +2 for Carista and Ive used it across multiple cars of multiple generations;)
    krmcg likes this.
  17. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    When collected my car from the dealer they'd already tweaked it to the one beep sound for reverse. Sales guy said everybody asks for it, so they did it for you anyway without waiting to be asked!
  18. walterm
    466
    202
    34
    2022 Prius Prime
    Now there's a dealership that does the right thing!
  19. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    I found out my particular salesman (who had just finished a Toyota course on the Gen 4) had moved on, so I may have to find another dealership to renew my lease in 2019. Aw, shucks! :(
  20. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    un
    I guess it's safe to do it on a Gen 4, the collision avoidance system makes it difficult to back into something.
    RCO likes this.
