Positive experience with Carista app.
Discussion in 'Gen 4 Prius Accessories and Modifications' started by The Professor, May 7, 2018.
  1. The Professor
    The Professor Senior Member
    486
    653
    UK
    Excel
    Carista is an app that allows you to change various options on your car yourself, that you'd normally need to take your car to the dealer (which may or may not incur a charge) to do.
    I've seen some mixed reviews on Google Play, and seen people who are hesitant to use it as they're understandably wary of modifying restricted settings.
    I already had a cheap ELM327 Bluetooth ODB adapter that I've had for a few years for use with the Torque app. It worked perfectly with Carista.
    I literally just plugged the adaptor into the Prius Gen 4 ODB port, turned the ignition on, launched the app on my phone, and told it to find what customisation options were supported. There are quite a lot. Some of which you can already change via the car's own settings menu, but a lot more that you can't.
    The changes I made were to change the reverse beep from continuous to a single beep, activate roll down/up of windows with long press of key fob unlock/lock button, single beep when doing that too, reduce volume of parking sensor beeps when stationary or moving away from objects, and a couple of others I've forgotten.
    When trying to change something for the first time, it does require payment. I chose £8.99 for 1 week, but there is also one around 3x that cost for 1 year.
    Turned ignition off, unplugged ODB adaptor, and tested the new settings... All works fine!
    If anyone wants screenshots of what can be customised let me know.
    #1 The Professor, May 7, 2018
    Rickyedger and krmcg like this.
  2. Rickyedger
    Rickyedger Junior Member
    Cincinnati, Ohio
    I would like to see what can be customized before I purchase everything. And do you know what the advanced features are it says the 4th gen cant access them.
  3. The Professor
    486
    653
    UK
    Excel
    No problem... Here's a list of the customisable options it can find. The Advanced Features Carista can access on other cars (none of which are accessed via the ODB port and/or aren't applicable on a Prius) are things like setting the service reminder interval, opening your electronic parking brake for servicing, counts of things like how many times Launch Control has been used, reading ECU firmware version, etc.
    Here's a list of all of the settings that can be changed on my 2017 4th Gen Prius Excel (UK). The option surrounded by *s on each setting is what I currently have my Prius set to, and may or may not be the default:
    Doors / Windows / Remote:
    Wireless door locking
    *ENABLED* / DISABLED
    Blink turn signals when locking/unlocking with remote
    *YES* / NO
    Beep when opening/closing windows with remote
    *YES* / NO
    Warn (beep) when door can't be locked because it's still open
    *YES* / NO
    Ding when key is left in the car
    Ding when key is out of the car and ignition is on
    *YES* / NO
    Warn (beep) when a window is still open when locking doors
    *YES* / NO
    Warn (beep) when sunroof is still open when locking doors
    *YES* / NO
    Re-lock doors automatically if you unlock, but don't open a door within…
    *30 SECONDS* / 60 SECONDS / 120 SECONDS
    After locking with smart key, don't allow re-opening within…
    0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
    Smart key location to start car
    FRONT SEATS / *ANYWHERE IN VEHICLE*
    Open trunk via smart access button
    DISABLED / DOUBLE CLICK / *LONG PRESS*
    Open windows and sunroof by holding key in door lock
    ON / *OFF*
    Close windows and sunroof by holding key in door lock
    *ON* / OFF
    Open windows and sunroof via long-press on remote
    *ON* / OFF
    Close windows and sunroof via long-press on remote
    *ON* / OFF
    Open driver's window using single button press
    *YES* / NO
    Close driver's window using single button press
    *YES* / NO
    Open passenger's window using single button press
    *YES* / NO
    Close passenger's window using single button press
    *YES* / NO
    Open rear left window using single button press
    *YES* / NO
    Rear-left window single-touch-close
    *YES* / NO
    Open rear right window using single button press
    *YES* / NO
    Rear-right window single-touch-close
    *YES* / NO
    Passenger window single-touch-open from driver's switch
    *YES* / NO
    Passenger window single-touch-close from driver's switch
    *YES* / NO
    Rear-left window single-touch-open from driver's switch
    *YES* / NO
    Rear-left window single-touch-close from driver's switch
    *YES* / NO
    Rear-right window single-touch-open from driver's switch
    *YES* / NO
    Rear-right window single-touch-close from driver's switch
    *YES* / NO
    Auto fold side-view mirrors (req. power folding mirrors)
    WITH IGNITION / *WITH DOOR LOCKS* / DISABLED
    Instruments / Display / Dings:
    Engine start indicator
    *ON* / OFF
    Display odometer after ignition is turned off for…
    *30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
    Reverse-gear beep
    *BEEP ONCE* / KEEP BEEPING WHILE IN REVERSE
    Ding when headlights are left on
    *YES* / NO
    Seat belt warning ding (driver)
    Seat belt warning ding (front passenger)
    Seat belt warning ding (rear passengers)
    Turn signal click volume
    LOW / MEDIUM / *HIGH*
    Lane-change turn signal auto-flasher count
    OFF / *3 FLASHES* / 4 FLASHES / 5 FLASHES / 6 FLASHES / 7 FLASHES
    Remote low battery warning
    *ON* / OFF
    Front parking sensor range
    NARROW / *WIDE*
    Rear parking sensor range
    NARROW / *WIDE*
    Mute parking sensor when stationary for more than 3 sec.
    YES / *NO*
    Lower parking sensor beep volume when stationary for more than 3 sec.
    DON'T CHANGE VOLUME / *1* / 2 / 3
    Lower parking sensor beep volume when moving away from objects
    Parking sensor beep volume
    1 / 2 / *3* / 4 / MAX
    Side parking sensor range
    SHORT / *LONG*
    Disable temporary muting of parking sensor above…
    AUTOMATIC / 15 KM/H / *20 KM/H* / 30 KM/H
    Activate parking sensors in neutral (N)
    *YES* / NO
    Auto-turn off parking display when moving away from obstacles
    *YES* / NO
    Lights:
    Coming-home lights duration
    *30 SECONDS* / 60 SECONDS / 90 SECONDS / 120 SECONDS
    Auto headlights activation threshold
    DARKEST / DARKER / NORMAL / *LIGHTER* / LIGHTEST
    Instrument lights dimming sensitivity
    DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
    Instrument lights restoring sensitivity
    Dim interior lights after…
    7 SECONDS / *15 SECONDS* / 30 SECONDS
    Turn on interior lights when you shut off engine
    *YES* / NO
    Turn on interior lights when you unlock doors
    *YES* / NO
    Turn on interior lights when smart key in range
    *YES* / NO
    Interior footlight (bright when doors open, dim when driving)
    *YES* / NO
    Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
    *YES* / NO
    Interior light control
    Heater & A/C:
    Ambient temperature calibration
    -3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
    A/C ECO mode
    A/C compressor noise reduction
    ENABLED / *DISABLED*
    S-Flow function
    Open air flow to footwell when AUTO button pressed
    *YES* / NO
    Auto-increase blower speed when front defroster is on
    *YES* / NO
    Auto-turn on recirculate mode when A/C is on
    YES / *NO*
    Open vents to outside air when ignition is turned off
    *YES* / NO
    Fan speed reaches its target…
    SLOWLY / *NORMALLY* / FAST
    Other:
    Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on
    *FAR* / REMEMBER LAST DISTANCE
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on
    FAR / *REMEMBER LAST DISTANCE*
    Pre-Collision System (PCS) sensitivity: remember last state
    Stop monitoring for car key signal after…
    5.0
    Obtained with Carista 3.6.4 for Android.
    mancuz28 and Harters like this.
  4. Harters
    Harters Active Member
    242
    357
    UK
    Excel
    Thats quite an extensive list, thank you.
    If they had the option to auto lock the car when putting it into Drive then I would get it, but alas its another thing our American friends get that we don't :unsure:
    StarmanUK likes this.
  5. The Professor
    486
    653
    UK
    Excel
    Yep. That's a feature I've had for several years on previous cars, and I was hoping to find the option with Carista. Alas, we don't have it here in the UK on the Prius either.
    SM-T813 ?
Loading...
