Back-up beeping
Discussion in 'Gen 4 Prius Technical Discussion' started by nednvermont, May 8, 2018.
  1. Mendel Leisk
    42,011
    I'd insist they take it back and restore full beep, lol. Not kidding: with the return-to-centre shifter, I need all the help I can get.
    I believe just disconnecting the 12 volt for a few seconds will accomplish this?
    krmcg and RCO like this.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I don't know why Toyota don't put the beeper outside the car, where we (the driver) can't hear it (or it's quieter for us), but pedestrians walking behind can.
    nednvermont and RCO like this.
  3. Mendel Leisk
    42,011
    If not rhetorical: it's a patch, for the mute, return-to-centre shifter. It doesn't really help much though. I'd much prefer a shifter you push through the positions, I never got lost with those.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Not on my Business Edition!
    kithmo likes this.
  5. krmcg
    2,592
    2,393
    Whittier, CA
    In my experience in my Gen 4, disconnecting the 12 volt battery does not change the carista options - or the saved trip meters or saved eco data on the computer. All it does is reset the clock.
    kithmo, RCO and Mendel Leisk like this.
  6. krmcg
    2,592
    2,393
    Whittier, CA
    I like having the reverse beeps. It has saved me a time or two in my 10 years of driving these cars.
  7. Prodigyplace
    12,696
    11,840
    Central Virginia
    Not all trims on the older Gen 4 had that. I think it is on all in the US now.
    kithmo and RCO like this.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Oh - that's annoying when vehicles beep - I can understand it on a construction site or a carpark area.
    But when neighbours reverse out of their yard in small trucks early in the morning (or any time of the day for that matter) - BEEP BEEP BEEP BEEP BEEP :(.
    kithmo, RCO and krmcg like this.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Agreed, I hadn't thought of that aspect. :oops:
    alanclarkeau likes this.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Doesn't the business edition have the collision avoidance or the warning beeps as you're reversing up to (or into) an object/wall etc. ?
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    My Excel version won't let me crash into anything at low speeds, it warns me with a red square on the MFD saying "BRAKE" then if I don't brake or swerve, it applies the brakes (emergency stop) just before it hits the obstacle.
    The first time I experienced this was as I was slowly turning into my drive and a some weeds were poking through the open gate from the right hand side, the sensor(s) picked this up and stopped me. The brakes applied with such force and the car stopped so suddenly that I though I had hit the wall that the gate was attached to.
    RCO, walterm and alanclarkeau like this.
  12. Mendel Leisk
    42,011
    Behind all this: what gear the car is in, is not readily apparent. There's a small display on the dash (ever look at it?) and the return-to-centre shifter, which is no help. The beep is a patch, to remediate these shortcomings, and not a very good one.
    I've lost track of the times of lost track that I'm still in reverse, beep and all. So far it hasn't been disastrous, but I did just about jump a curb once.
    I appreciate it's all electronic, doesn't need to hold a position, but: the traditional automatic shift, at least for me, is so much more intuitive. Please please please Toyota: consider mimicking a traditional shift, say something like this:
    (Honda Pilot dash)
    RCO likes this.
  13. Salamander_King
    Salamander_King Senior Member
    11,024
    8,972
    New England
    Hmmm, am I the only one actually like the back-up beeping? It does let me know if I accidently put the gear in R instead of D.
    RCO likes this.
  14. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    Yes, you are the only one :)
    Tyfly, alanclarkeau, kithmo and 2 others like this.
  15. Mendel Leisk
    42,011
    Nope, he's not alone. Still pretty useless, doesn't stop me losing track sometimes, but better than nothing.
    Referring to the pic I posted above: the linear shifter, where you push it from one gear to the next, is so much better at keeping you oriented.
    Salamander_King likes this.
  16. Salamander_King
    11,024
    8,972
    New England
    My natural tendency is to put gear in forward (in Prius it is more like "upward") for Drive. I don't know why many cars put R position on top of D.
  17. Mendel Leisk
    42,011
    I think that's very common; all our Hondas were thus. The main thing I think:
    Don't get clever, change from the norm, throw in a cutesy return-to-center shifter. I think Toyota's hit all of those, lol.
    I like the traditional shifter. If for example you wanted to push it into neutral, to reduce transmission shudder at a red light, you pushed it away from you, as far as it would go without your thumb on the lock button. This would put in in Neutral, with no risk of going into reverse. Light goes green: you pull it one click towards you.
    This gets ingrained, muscle-memory as they say, and it's so common.
  18. Salamander_King
    11,024
    8,972
    New England
    I found this information.
    P-R-N-D is a US government standard, specifically US Department of Transportation Standard No. 102. (It also mandates starter interlock, direction of shift pattern on column mounted selectors, etc)
    At least for my old Honda, P-R-N-D was sequential. From Parked position, I had no way to shift FORWARD. With Prius, from Parked position I can shift the knob either Forward for R or Backward for D. I can never get used to this.
    #38 Salamander_King, May 31, 2018
  19. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I love the joystick shifter and I have never been in a situation where I didn't know what gear I was in. I have the beeper set to beep once.
  20. krmcg
    2,592
    2,393
    Whittier, CA
    Not alone...
