BACK UP CAMERA FOR 2012 PRIUS two TOUCH SCREEN- NON NAV
Discussion in 'Gen 3 Prius Accessories and Modifications' started by man2ing, Jul 4, 2012.
  1. priusbee
    priusbee Member
    125
    SF Bay Area
    Can you show us the Camry Camera installed on your Prius? Thanks!
    If you take a look at DumLong's camera installed on the Prius, it does not look aesthetics at all.
    It makes it look shoddy in materials and workmanship.
    It does not do the Prius any justice. You know what I mean?
  2. kumatae
    kumatae Member
    101
    So Cal
    2014 Prius v wagon
    Priusbee, I know what you mean. I'll make sure to provide a good DIY. I ended up ordering the 2012 Prius Rear View Camera and it was delivered yesterday. I'll get it going hopefully sometime this month.
  3. dimetech
    dimetech Junior Member
    31
    Los Angeles
    I ordered the same camera from this seller. The wires coming out of it are a red and black in one cable and inside the RCA video cable is a tiny yellow wire and an unshielded copper wire. Maybe this is obvious to some, but are the red + and black - camera power? And the yellow is the video feed and u shielded is ground? How come others are red black orange and white? I'm pretty good with electronics (have built my computers for years, but these are odd. Which of these wires get routed to the driver kick panel?
    Firephoenix1980 likes this.
  4. dimetech
    31
    Los Angeles
    Sorry for the double post to get another pic.
  5. dimetech
    31
    Los Angeles
    Ugh can only upload one pic at a time from my phone.
  6. priusbee
    priusbee Member
    125
    SF Bay Area
    The Sony CCD camera you purchased, how is the fit to the rear hatch?
    Can you take a few pictures?
    Thanks!
  7. kumatae
    kumatae Member
    101
    So Cal
    2014 Prius v wagon
    dimetech, I just received my camera as well. Not the exact same camera but very similiar. The red and black cable is your power. So you want to connect the red one to a 12V power source such as the rear wiper or reverse lights. The black cable is the ground. You can route this to the front panel but you are better off grounding it in the back. I'm sure you can find whole bunch of wires tied together on to a metal bolt when you take off all of the panels. So the only the video cable needs to be routed up to the panel - unless you are planning to do it under the headliners. The tiny yellow wire from the video cable is your video+ (goes to pin 8) and the unshielded is your video - (goes to pin 16). Please correct me if I'm wrong. I plan to do it sometime this month, just haven't had the free time yet.
  8. dimetech
    31
    Los Angeles
    Thanks for the insight. I figured this but wanted to make sure. I'm planning on running to the driver kick panel because I don't want to mess up the headliner on a brand new car. I'll be updating whenever I get around to it as well. PS is your name a reference to bloodsport? I love that movie.
  9. kumatae
    kumatae Member
    101
    So Cal
    2014 Prius v wagon
    Yeah it sounds like kick panel is the way to go. And yes, bloodsport! JCVD!!!
  10. our1vue
    our1vue Member
    313
    58
    NY
    kumatae,
    Where did you get your prius camera, from a dealer ? Thanks
  11. kumatae
    kumatae Member
    101
    So Cal
    2014 Prius v wagon
    I bought this from ebay.
    Sony CCD Car Rear View Reverse Camera for Toyota Prius 2012 | eBay
    It's only $21 and it has a nice solid OEM install. The wiring is pretty much the same except it's 12V. I figure, if it has any issues, I can just buy another one and install it fairly quick using existing wiring. More to follow in couple of weeks.
  12. our1vue
    our1vue Member
    313
    58
    NY
    kumatae,
    One more question. Are you going to install it in one of the license plates lights or in the camera slot to the left of the license plate ? Thanks
  13. kumatae
    kumatae Member
    101
    So Cal
    2014 Prius v wagon
    slot to the left of the license plate. from what i understand, it fits perfectly in there without much modifications like an oem camera. my wife has a 2010 and this camera is for my father in law who has a 2011 and i'll probably get around to it next week or so. i've never seen what this slot looks like but if it's anything like the 2011, it shouldn't be too difficult to place it in there.
  14. ray6088
    ray6088 Junior Member
    70
    23
    please follow this diagram. It works great for me ^~^
    priusbee likes this.
  15. priusbee
    priusbee Member
    125
    SF Bay Area
    Hi Ray,
    Which backup camera did you use?
    Do you have a picture of the fit?
    I notices, there were several cameras out there, but some of them does not fit like the OEM.
    Thanks!
  16. ray6088
    70
    23
    see post #42 for camera item. It snap on perfectly. No drilled at all
    See post #84 for pics
  17. priusbee
    priusbee Member
    125
    SF Bay Area
    Hi Kumatae,
    I just received the camera from your recommended vendor above.
    I have one question, did you just hook up the 12-volt backup brake light?
    No diodes are required? Correct?
    BTW, how is your setup with this camera? I love to hear your feedback.
    Thanks!
  18. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Firephoenix1980 and priusbee like this.
  19. ray6088
    70
    23
    It works great for me.
  20. priusbee
    priusbee Member
    125
    SF Bay Area
    The link (http://priuschat.com/attachments/camera2-png.42170/) uses a relay.
    I prefer not use a relay. Mechanical contact wears out.
    If I don't use a relay, will the modification using the two diodes work just as well as the relay?
    The camera vendor diagram only uses 12V to power the camera. Is that the correct voltage for the camera?
    Will a straight 12V works?
    I am confuse about the 6-volt and 12-volt hook up. Does the voltage for the camera uses a standard 6-volt or 12-volt?
    Thanks!
