Back up Camera guide lines
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jreres51, Jun 1, 2017.
  1. Jreres51
    Jreres51 Junior Member
    Deleware
    I have a 2014 Prius 4
    Has anyone come out with a fix for no guide lines ?
  2. Bill32803
    Bill32803 Junior Member
    27
    Orlando Florida
    This subject has been going on for a couple years. It appears the Prius' shipped to the US and Canada didn't get the backup lines programmed into computer. I had a 2014 rental in Europe that did, but my 2014 here in the US does not. Think we're out of luck.
  3. Jreres51
    Deleware
    I reciently found a article that told you to put it in the acc mode 5 times in a row , then put the car in rev. Well you can't put it in rev in acc.
    So the lines are in the radios software? Is that obtainable ?
    52,831
    welcome!
    unfortunately, we don' know if they are in there, and if they are, no one has been able to retrieve them.
    if you really want them, you would have to upgrade the h/u.
  5. Jreres51
    Deleware
    Thank you ,
  6. afob3
    afob3 Member
    124
    40
    TN
    I've just adapted. Perhaps that is the wrong word as I never had a backup camera before this car. When backing into a spot, I've found that if I line up the painted line on the asphalt with the bottom right corner of the display, I'll be fairly centered in the spot.
  7. Jreres51
    Deleware
    Thanks for the idea, I have a white car and was toying with putting 1/4 inch wide strips of white reflective tape on the bumper as a guide .
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I'm reviving a slightly old thread here because I missed it earlier and I don't think we really need yet another thread on the topic.
    The only time the lack of backup camera lines bothers me is backing into my garage, which I just started doing because that way there's no danger of further damaging the spoiler on the garage door. The lack of lines is an unconscionable oversight since it seems to be just a matter of programming it like the European models.
    Anyway, I laid down white duct tape on my garage floor which helps a lot, but isn't a full fix. It's very hard with this car, when backing up, to know which way the car is pointing because of the sloping window sills, as you can see in the picture. And it's hard to judge left and right distances from the sides of the garage door opening since one outside mirror is convex and the other is flat. Short of building an aiming device like what NASA used in docking Command Modules with Lunar Modules, I'm at a loss for a real fix.
    Except ... This looks interesting, other than I don't want to spend $100 fixing Toyota's cheapness.
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Good cheap idea and fix(y).
    Todd's logos are large and in charge. Everyone knows where got your Prius when driving around:).
    jerrymildred likes this.
  10. jerrymildred
    11,517
    14,167
    Tampa, FL
    A shameless little plug for my friend, Todd. Last time, I took the letters off after a few months. So did the wife. This time, I'm leaving them till they get ratty looking. :D
