Back-up camera
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dr_rock, Jan 4, 2014.
  1. xliderider
    xliderider Senior Member
    8,139
    3,274
    Honolulu, HI
    It's wireless because you don't have to run wires between the camera and front monitor.
    You still need to do some wiring at the back for the camera and the transceiver, and at the front for the wireless receiver and monitor.
    SCH-I535
  2. Lucky Lager
    Lucky Lager Junior Member
    87
    Will that be possible with my lcd monitor in rearview mirror? Or should I do a wired one?
  3. jackytabo90
    jackytabo90 New Member
    Hey man, you looking for backup camera for your prius - I would recommend you tadi brothers.
  4. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    is there a way to adjust the factory camera. for me the direction it points seems to be "off a bit" it really favors the drivers side.
  5. Lucky Lager
    87
    I guess my question is if the camera is wireless with a transmitter, what receives the signal in your Alpine head unit? I guess thats what I can't figure out.... I can see a package (camera and monitor) would work fine together, 2 pieces with transmitter/receiver guts.... But this camera can transmit to an Alpine? Thanks for any guidance...
  6. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    The wireless receiver hooks up to the head unit.
  7. Lucky Lager
    87
    Ok, sounds good, so it would be feasible to tap a wire off an lcd rearview mirror and get the same result? Sorry to bother u again. Thanks for the help
  8. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Yes it should work.
  9. Lucky Lager
    87
    Ok, I need one of you wiring experts to explain this to me like Im 5 years old lol.... Seriously need an expert out there, anybody smarter than me....that may be all of you... I have an LCD rearview mirror and want to hook up a back up cam to it, the camera comes with a wireless transmitter and this is actually what is tripping me up --(I do not need a wireless connection, I have no issue with running wires..FYI. but what would I need..a double male ended rca cord?
    Can I just throw away the transmitters and use an RCA cord(Do I need RCA cord? Seem so they are the only lead off the camera) - whats the easiest way to run this thing? It just needs peer, ground, and reverse trigger...
    Or can I just run the 3 wires, power, neg, and reverse?...
    ***only thing I can think is the one transmitter with GPS jack needs to be a transmitter with an RCA lead..... I think they messed my order up*****
    Heres the set up (Mirror and harness did not come with the camera)
    Pic 0 - shot of whole set up
    Pic 1 and 2 - I suppose this is the mirror end of the set up -Transmitter 1
    Do not know what this can hook up to -see the 2 leads-
    Pic 3 and 4 - mirror with supplied harness
    Pic 5 camera end transmitter with wire leads
  10. Lucky Lager
    87
    I think what threw me off was they sent me the wrong wireless transmitter, they sent the one for hooking up to a monitor or GPS monitor..... if I get the right xmitter I will be fine....thanks - threw me for a loop.
  11. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    By looking on your pics, yes the Seller indeed send you the wrong wireless kit.
    I do have a GPS rearview monitor on my Odyssey which uses 2.5mm plug for video input, same as your pic.
    This is the one you'll need to make it work
    2 4G Wireless Transmitter Receiver for Car GPS Rearview Camera Video Monitor RF | eBay
    OR Hookup direct, which has zero snowily video feedback vs wireless.
    15 ft RCA Composite V Video Cable Male to Male | eBay
  12. Lucky Lager
    87
    Thanks! Yeah I'm ditching the wireless crap - wanted the "made to fit" prius camera though. Thanks again
  13. sangahm
    sangahm Junior Member
    So if I wanted to add the wifi camera to my stock 2012 Prius that only has the radio screen, I would need to add these 2 items?
    Wifi Camera
    Interface Kit
    How good a connection is the wireless unit? Does it get interference? Any other cons to this approach?
