Backup beeps
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bgattsek, Jul 20, 2015.
  1. bgattsek
    bgattsek New Member
    Is there some way i can turn off the backup beeping, I've not seen anything for the 2012 Prius, and the instructions I have found online do not work.
    52,725
    welcome! you can try it with a code reader, or ask your dealership for a freebie.
  3. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    You can't turn it off completely, but you can reset it to just one beep. You need an ODB2 device (like the one below) that plugs into the ODB port and then a phone/tablet you can connect via Bluetooth with an app that will let you communicate with the ODB device. ELM327 Terminal is one such free app, but it has a command line type interface that can be difficult. Carista is another app often mentioned here. I has a nice GUI type interface and works with a wide variety of settings that can be changed. I believe it still has a trial period and then costs $0.99-$19.99 after that depending on what options you want to purchase. As others have mentioned, some dealerships will change some codes for free.
  4. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Unfortunately the Gen III can only be adjusted to 1 beep in reverse whereas the Gen II could be turned off altogether. When I traded in my 2008 for my 2013, the first thing I told the dealer was that I wanted the reverse beeper changed. The dealer acted like it was a big problem but I told him the car wasn't leaving without having it done. It took the mechanic 5 minutes to do it.
  5. 1prius2nv
    1prius2nv New Member
    Vacaville CA
    Where are you located? If near the bay area I can do it for you. That one beep when put in reverse is such a sweet sound!
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I suspect any instructions you found online were for the Gen 2 Prius, where the beeping could be turned off without tools.
    The Gen 3 Prius can have the constant beeping turned to one beep by:
    1) the dealer can do it with his software. (this is often free, especially if you negotiated it before the sale)
    2) you can buy an On Board Diagnostic II scanner like the Scangauge. ScanGauge II ODB Scan Tool + Digital Gauges + Trip Computers - PriusChat Shop
    3) you can download software to make your bluetooth Android device into a OBDII scanner, and buy a bluetooth to OBDII conveter.
    Torque Pro (OBD 2 & Car) - Android Apps on Google Play
    Amazon.com: Panlong Bluetooth OBD2 OBDII Car Diagnostic Adapter Check Engine Light for Android - Compatible with Torque Pro: Automotive
    I chose option 2
  7. 1prius2nv
    Vacaville CA
    I have a 2012 prius and customized mine to just have the one beep when in reverse. Thats why Im actually only able to guarantee my service to Gen 3 owners.
  8. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    "Customized" as in got a scangauge or one of the other items mentioned in JimboPalmer's post?
    By the way, welcome to the forums. :)
  9. 1prius2nv
    Vacaville CA
    I got a wifi ELM327 adapter and use the carista app to customize or change settings on the Gen3 prius. And thank you, glad to be part of the group
    #9 1prius2nv, Jul 24, 2015
  10. nsb
    nsb Junior Member
    33
    Hawaii
    best "mod" done in my whole life haha! drove me crazy
  11. bisco
    52,725
    i have 11 years of beeping in my portfolio, i'm not going to wash it all down the drain now...:barefoot:
    #11 bisco, Jul 24, 2015
    nsb likes this.
  12. blacksapphirez
    53
    39
    Alabama
    I used the Torque App and downloaded the extra PID's as directed and turned seat belt chime and back up beep off!
    lumpy95 and bisco like this.
  13. cheizy
    cheizy Member
    94
    129
    Los Angeles
    I just brought mine into my dealership while getting my service done. Just asked them about changing it to 1 beep. They might give you a hard time about the safety of it yada yada since the Prius is so quite, but be persistent. First the service personal gave me a hard time and said it would cost me some $$, then I told her it would literally just be 5 mins for the tech to do it. Got it done free, and now I have 1 beep. Definitely a must do mod.
  14. LuckyName
    LuckyName Junior Member
    50
    Los Angeles, California
    I don't understand why people are so annoyed by the beeping. I don't mind it and believe it goes unnoticed. In fact, I had to go and listen to the beep after reading through a few posts here because I didn't even know it did it. That's how unnoticed the beeping was for me.
  15. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Hmmm, possibly a hearing test is in order. Just kidding. To me, I don't have a clue how you could miss it!! :eek:
    BTW, welcome to the forum. :)
  16. bisco
    52,725
    what?
    HybridBull likes this.
  17. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Sorry, I can't hear you, my reverse beeper is going off.
    HybridBull and bisco like this.
  18. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    We have an echomaster ultrasonic reverse sensor system installed. It beeps at varying intervals to alert you to how close approaching objects are. Two sets of beeping while in reverse is unacceptable.
    cheizy likes this.
  19. nsb
    nsb Junior Member
    33
    Hawaii
    amazing! The first time I put in reverse I literally ran to the computer to google how to turn it off hahaha
  20. HybridBull
    HybridBull Junior Member
    Tampa
    I had my reverse beep turned off this weekend during my first service visit to the dealership. I'm so happy that it is gone!
