Backup camera added but having screen quality issue
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jama707, Oct 23, 2021.
  1. Jama707
    Jama707 Junior Member
    SACRAMENTO, CA
    I’ve added an a backup camera to existing MFD but having greenish/yellowish washouts not sure what could be a problem. This is what I did:
    Used this harness https://www.ebay.com/itm/Rear-View-Back-Up-Camera-Wire-Harness-Fit-For-Toyota-Prius-RAV4-Scion-Subaru-BRZ-/184968250815
    and this camera
    https://www.ebay.com/itm/170-Car-HD-Rear-View-Backup-Camera-Parking-Reverse-Cam-Night-Vision-Waterproof-/393125132581
    so I tapped into heated seat fuse and wired it to harness power and grounded it to MFD’s bolt. I connected RCA’s little red wire to to the same fuse tapped source. And then used the fuse tapped source for the camera and grounded cameras negative to a bolt.
    But I can’t find the cause of this color issue. Appreciate if someone could help. Thinking of ordering another backup camera because this one is kinda cheap one.
    https://youtube.com/shorts/7U0L7hHkX2A?feature=share
  2. CivicSky
    CivicSky Member
    169
    71
    San Deigo
    I installed this with my $150 Android stereo head unit. Good quality even with low light.
