Backup camera cover
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Paul Gregory, Feb 3, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I got the idea from my VW. The camera is retracted behind the VW badge until you go into reverse. In reverse, the badge flips open and the camera extends into position. It works great; I've never had to clean the lens so far. I don't know of any other vehicle that does this.
    My plan is to use a small linear actuator and a DPDT relay. The arm would have a cover with a fiber pad attached to keep the lens covered and dust free while driving. The backup light circuit should activate the relay to cause the actuator to retract. When the backup circuit is off, the contacts relax and apply reverse polarity to make the actuator extend, covering the lens. The actuator has cutouts at both ends of the stroke. I imagine I will need 3 wires to the unit; a 12V live, a backup trigger and a ground.
    I plan to mount it all in a 3D printed enclosure, attached with mounting tape, and the wires will run under the weather stripping to their destinations. This way, I won't lower the resale value by drilling any visible holes.
    I'm still in the planning phase, but I have purchased the relay and actuator. I tend to get better results, the more I think about the project.
    jbbass likes this.
  2. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    Now that I can upload pictures...
  3. Blackat
    Blackat Active Member
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    I live in the mtns with snow, mud etc.
    It's annoying that Toyota didn't think this one thru.
    It gets dirty fast and then worthless
  4. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I got into the habit of wiping my finger on the camera lens before getting into the car. Learned this on previous vehicles.
    Louis19 likes this.
  5. sylvaing
    sylvaing Senior Member
    1,221
    517
    Toyota recommends against doing that as it scratches the lense.I'm guessing the previous owner of my 2017 Prime did that because my lense is scratched. I was able to remove most of the scratches using
    Meguiar's ScratchX as these before (second picture) and after pictures show.
    I have a small 3" spray bottle filled with washer fluid and a microfiber cloth that I keep in the car to clean the lense when it gets too dirty (happens mostly in the winter). That bottle is filled with a water less wash solution in the summer to clean bird droppings from the car when not at home.
    #5 sylvaing, Feb 24, 2024
  6. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    The problem is that even when you wiped it with a damp glass cleaner sheet, it gets dirty again before the next time you need it.
    My goal is to build a retractable cover that has a soft pad contacting the lens, which retracts when the car goes into reverse, and extends the rest of the time, covering the lens.
    My other car, a VW has a retractable camera that only extends when you back up, and remains covered the rest of the time. I haven't had to clean the lens for the year I've had it.
  7. sylvaing
    1,221
    517
    Yes, a retractable cover would work nicely and be preferred (even a wiper fluid jet would do a good job on a ceramic coated lense). I was replying about wiping the lense dry, which should not be done.
  8. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Agreed that wiping it when dry will scratch the lens cover. Fortunately, the weather here is always rainy and wet when I wipe the lens.
    sylvaing and Louis19 like this.
  9. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Yep ,moisten your index finger with saliva will do :)
  10. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I use Simoniz glass cleaner wipes. When I install my camera lens cover, it shouldn't scratch the lens, because it shouldn't have any dirt on it, having been exposed only when I'm backing up.
  11. Zeromus
    Zeromus Active Member
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Is ceramic coat safe on the lens? I know so many products have so many different "don't use on plastic/glass/electronics/etc" warnings I didn't think about it.
    I just have a small bottle of quick detailer and a microfibre in the trunk for general touch ups and to wipe the thing off
  12. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I plan to include a microfibre pad inside the cover. If that scratches the lens, I'll just use something else.
  13. sylvaing
    1,221
    517
    I meant something applied at the factory to go in hand with the factory installed washer. Otherwise, droplets left on the lense would make viewing the camera worse.
    Yeah, quick detailer and waterless wash are basically the same. I use Turtle Wax Hybrid Solution 3-in-1 Quick Detailer in a small spray bottle. It's basically a waterless wash, to be used on dusty car, not dirty but works well for removing dirty spots like bird droppings (that hasn't baked for days).
  14. Zeromus
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Ok yeah then we're of the same thinking.
    The top trim does have a washer fluid sprayer on the Prius prime but like... The number of practical things I wanted vs number of less practical nice to haves was high and 10,000$ is a lot of money when you're financing.
    Maybe when my family is older we can have different priorities but with little kids... I'm ok with a cloth to wipe off with.
    Though if this thing Paul is working on is a relatively easy DIY project, I'd be happy to try and follow along and do it myself later. I've a friend with a 3D printer who could help me out if the designs are posted up for free in the end.
