Backup camera gone black
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MandaPanda, May 12, 2018.
  1. MandaPanda
    MandaPanda Junior Member
    The Commonwealth
    2014 Prius v wagon
    I have an '08 Prius with less than 130k miles on it-- the car is new to me as of last September. It is a touring package 5, which includes navigation and backup camera, all OEM.
    My backup camera is no longer working. When I shift into reverse, there is a black, blank screen that does include the warning text to check my surroundings. Turning the car on and off (just once) did nothing. The rest of the center console display works as expected.
    I took a cell phone video that shows that the black images is actually a very very dark, horizontally scrolling image of the camera view.
    The camera failure happened to me at the end of a few drives that day It worked perfectly until I got home. The weather was in the 70s and sunny. I have never had any issues with the backup camera before.
    Earlier that week, I drove on a dirt road that shook the the car and the dash more than I would have liked. My car gets parked in a horrible garage, and bottoms out at when entry. Perhaps some connection got loose somewhere? If this is the case, is this something I could easily check and fix myself? Where? How?
    If not solved, I will have a mechanic look at it during the week. What repair costs can I expect?
    52,847
    start at the back and make sure the lens is clean and stable. then check the connections from there all the way under the car and behind the mfd. if everything looks solid, you'll have to test the camera and the mfd which is a more complicated procedure.
    estimating repair cost is difficult not knowing what is wrong. i'd guess between $100. and $500.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Never seen anyone complain the back up camera went out. I searched using the search forums button up top.
    Going to be tough fixing that one. Since your mfd screen works otherwise it probably is the camera itself.
    If it was me I would go to a junkyard and pull one out of a g2 and replace yours, go to toyotechinfo.com and buy a one day subscription to the service manual and print out how to remove the camera,
    It’s pretty easy take cover off the back of the hatch and take a look.
    JC91006 likes this.
  4. JC91006
    16,936
    8,647
    Camera replacement is very easy. But I would suspect it's more of a connection issue. I would check the wiring first.
    If you do need a camera, I think I have an extra one, just send me a message when you need it
  5. Mendel Leisk
    42,343
    Oh yeah, we think alike.
  6. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Op states says sees a very dark horizontally scrolling pic. That’s not wiring and that’s not dirty lens.
    But JC says it’s easy.
    Never replaced one myself.
    Mendel Leisk and JC91006 like this.
  7. JC91006
    16,936
    8,647
    Yes easy, remove the rear hatch trim. Remove the 4 nuts holding the rear garnish for the trunk release. Camera is right there. Maybe 10 minute job
  8. bisco
    52,847
    what do you do after you get to the camera?
  9. JC91006
    16,936
    8,647
    Unscrew the 2 mounting screws. disconnect the clip. Put on new one
  10. bisco
    52,847
    ah, thank you. what do they go for?
  11. Patrick Moloney
    Patrick Moloney Junior Member
    Milwaukee, Wiscoonsin
    I have an '06 Prius that suddenly developed a black fuzzy screen when put in reverse. Are replacement instructions same for '06 and '08? Any recommendations on where to get replacement camera?
    Thanks
  12. Patrick Moloney
    In advance of getting a replacement camera I removed the plastic covering on inside lower hatch which popped off easily. I see where the camera cord connects via a clip to the wiring bundle. The camera looks very hard to access under the outer metal layer of the hatch frame. There appears to be 6 small allen wrench type screws but I can't see how to get at these. I forgot to snap a picture. Any advice on how to proceed. I was really hoping to do this myself.
    Thanks
  13. bisco
    52,847
    is the camera lens clean?
    Patrick Moloney and Mendel Leisk like this.
  14. Patrick Moloney
    I wiped it off. It looks clean. My wife had taken it to the dealer and was told camera needed replacing - $900. Attached are puctires of MFD and camera area ince plastic inside hatch cover removed 20180610_145918.jpg 20180610_150040.jpg
  15. Prius4Free
    Prius4Free New Member
    United States
    Has anyone had luck resolving this issue? My 2009 loses its camera when it gets warm, but otherwise it works just fine. The camera has been replaced, and this had zero impact.
    The MFD works perfectly except it does not display the image from the camera after the car has become warm on a 70 degree or hotter day, instead showing the scrolling black/white heavily distorted camera image with the normal orange text warning at the bottom of the screen described by the thread starter.
    I was naively hoping this would be related to the combination meter failing (mine would go out on very cold days), so that repair was done last weekend, and as a result I can confirm the wires all plug firmly into the MFD and the camera. Thanks for any help.
