Backup camera install help
Discussion in 'Gen 3 Prius Accessories and Modifications' started by wesayso, Feb 20, 2014.
  1. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    I just installed a Pioneer AVH-X3500BHS. Where is a good place to install a BU camera, and what is the best way to route the wiring to the head unit? I've dug thru searched posts, and cannot find what I need.
  2. our1vue
    our1vue Member
    313
    58
    NY
    I don't know what the 2011 looks like, but the 2012 has a D shaped cutout in the rear hatch made for the camera. If you look to the left of the license plate lights under the overhang, you should see a black piece of plastic covering the hole. There are a lot of cameras that just snap into that hole (once you remove the plastic cover). In the "Audio and Electronics" section, there are threads about installing a backup camera in a 2012 prius. They also show how to run a wire from the back hatch to the driver's kickpanel. From there, you are on your own :). But from there it is only 3 more feet to the back of the radio and you are behind/under the dash, so it shouldn't be too hard to route the wire from there.
  3. kehyler
    kehyler Member
    68
    26
    blah
    Did you ever instal your camera?
