backup camera lens cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MZT, Mar 4, 2019.
  1. MZT
    MZT Junior Member
    ATL
    Hi guys,
    The backup camera in my 2010 Prius is kinda foggy and I tried to clean the lens but seems it seems that it's from the inside of the lens cover and cleaning the outside doesn't help.
    Any idea how I can remove and clean that lens cover?
    Thanks!
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    If you believe the fogging is from water condensing in the lens, rather than a layer of dirt, try some gentle heat such as parking with the camera catching the low, late day sun. You could also try using a hair dryer near the camera. Find the distance that would not be too uncomfortable if you held your hand over the lens. If it is actual dirt in the lens, then all bets are off and you probably need a replacement.
    MZT likes this.
