Backup camera now comes on with turn signal
Discussion in 'Gen 2 Prius Technical Discussion' started by David Scott Dallas, Jan 21, 2020.
  1. David Scott Dallas
    David Scott Dallas Junior Member
    39
    Dallas
    I went over a bump and now my backup camera comes on with my turn signal. On and off with the flash. Also when the signal is on, the other signal light comes on a little. Wth?
  2. David Scott Dallas
    39
    Dallas
    Nvm. Two white ground wires broke at the connection to ground. All fixed. My bad for posting.
    MickyMatter likes this.
  3. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    You've posted a problem.
    You've posted a solution.
    Maybe helpful to someone sometimes in a similar situation!
    SM-G950F ?
    David Scott Dallas likes this.
  4. David Scott Dallas
    39
    Dallas
    OK then, for the record it was two white ground wires that connected together and then to a bolt that also had a separate single white wire connecting to it. Mine that broke was the thin metal part and I just stripped the wire bear for a short stretch near the end, loosened the bolt(10mm) And then tightened it down on the wires. The wires and bolt in question are in the back wall of the spare tire tub right in the center of the wall. Staight below the latch
    MickyMatter and SFO like this.
  5. ydpplqbd
    ydpplqbd Active Member
    551
    254
    Answered!!!
  6. ETC(SS)
    7,579
  7. spdracrm3
    spdracrm3 Member
    60
    48
    estacada or
    Location of said ground wires(maybe even a picture), again might help someone in future.
    Thanks for posting issue/solution
    SM-G960U ?
