Bad 12V battery
Discussion in 'Gen 2 Prius Technical Discussion' started by CharlesS, Jul 15, 2016.
  1. CharlesS
    CharlesS New Member
    24
    Buckeye, Az
    So it only needs to be a 12v battery, what about amps? When they tested the battery at the auto parts store they said the voltage was fine but the amps were low?
    52,807
    the amps are just for longevity. you need enough to open some relays, but i don't know how much, it's pretty low.
    check your owners manual for the car symbol with wrench meaning. maybe that's a clue.
  3. CharlesS
    CharlesS New Member
    24
    Buckeye, Az
    Was able to power the car on using the jump pack. Apparently you have to have the emergency brake on to do this? I didn't have to the other two times but this time I did. Manual also said to disconnect the Hybrid battery, orange quick disconnect located on the left (drivers) side of the Hybrid battery. When I power the car on all of the dash lights come on and stay on, my scan tool lights up when plugged in but nothing shows on the display. Still reading through the manual, sounds like might have something to do with the 12v battery being disconnected.
  4. CharlesS
    CharlesS New Member
    24
    Buckeye, Az
    I have been able to power the car on using the jump start pack several times now, more than before. I can get the display screen to come on, tune the radio, see the energy and consumption screens, and enter the diagnostic menus only while powered by the jump pack (think the battery is too week to run on its own). However, the hybrid system will not engage I can shift from park to neutral only. I have a full line of the orange warning lights, sometimes the red triangle will come on as well but not always. I have also been able to use my scanner to check for codes and it keeps coming up with no codes found. I know the optimal thing to do would be to have it towed to the dealer for a diagnostic, but I just don't have the money for any of that I am about broke as it is. Is there anything else I can do myself or is it pointless with the limited capabilities that I have?
  5. bisco
    52,807
    never heard of emergency brake before, seems like something is off.
    what manual said to disconnect the hybrid battery? you need it to start the car.
    why don't you try the lawn mower battery just for kicks.
  6. CharlesS
    CharlesS New Member
    24
    Buckeye, Az
    2007 owners manual says to apply parking brake on page 361. As for removing the disoconnect from the hybrid battery, I had either read that online here or in the manual somewhere (can't find it now) but it doesn't really seem to make a difference either way. After replacing the orange disconnect the hybrid system won't engage as it did before. Should I leave the jump pack connected for a longer period of time? As for trying the lawn mower battery, I don't have a way to the store right now and really don't want to spend the $$ if its not going to help. I'm seriously at a loss for what to do.
  7. bisco
    52,807
    no, leaving it connected won't hep. better to leave it plugged into the wall.
    are you sure you reconnected the orange safety plug correctly? there's an online video, and it's tricky, and not intuitive at all.
    if you bought the jump pack from the store that jumped your battery, call and ask for advice.
  8. CharlesS
    CharlesS New Member
    24
    Buckeye, Az
    Yeah I have the safety plug reconnected as shown in all of the pictures on here, bit tricky yes but its pushed in all the way and latched.
  9. bisco
    52,807
    check your manual, and make sure all fuses are good.
  10. CharlesS
    CharlesS New Member
    24
    Buckeye, Az
    I have checked the two fuses in the box on top of the 12v battery, and several that are in the panel under the dash and under the hood. This was all stuff I had thought about and tried but still seem to be getting nowhere. I'm going to keep trying just to see if anything changes.
  11. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    Just to be sure, because your wording does not indicate you pushed the safety interlock down once rotated up, so I have attached an image of the 3 step process.
  12. CharlesS
    CharlesS New Member
    24
    Buckeye, Az
    OMG!!!! I can't believe it. I have had that stupid thing out a dozen times and put it back in. I thought I had it in just fine, just went and checked and sure enough the handle did push down while in the upright position. Car started with the jump pack (12v battery is definitely toast) no warning lights, drove it around the block just fine. I borrowed a friends battery charger and tried charging the 12v battery, read about 8v out of the car, charged up to 12.6 or so in about 30 minutes and about 10 minutes later back down to the 8v range.
  13. bisco
    52,807
  14. CharlesS
    CharlesS New Member
    24
    Buckeye, Az
    I can't believe I spent days chasing a problem that was just something so stupid, and apparently it is rather easy to "bump" the handle out of position as I did when I was putting the 2 piece cover back over the spare tire. What a freaking PITA, I have probably lost my job over not being able to be to work since Wed.... Jeeze!
  15. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Bottom line: your 12v is nearly dead; AZ summer heat is the final nail.
